Section
john_brodowski
Member Posts: 37 ✭
I made RF Horn ass`y public, and this is my question.
How do reference the section without planes, they are not visible on the model.
Is there another way to section an item ?
I am still unable to import STEP files. I get the part no. but no 3D model.
Regarding the problem with your step file, if you can share the file here in the posts so we can take a look it will help.
I will make public all my documents. STEP is listed there.
I have a problem with the Sweep commend.Please look at the coil. It twists, gives angular displacement to the end profile.
It is not congruent with the mating profile.
It could be done with the Loft commend, but it would be very laborious
I mentioned this issue with the Support, never received an answer.
Thank you very much
I will not elaborate on the issue, but it is self evident upon examination of the part .
The Sweep issue in short.
1. Share the URL of your model
2. If the file with problems is RF horn, there are no sweep operations on Part #3 just Loft operations
