Forum Code Block's Broken
MichaelPascoeMichaelPascoe Member Posts: 2,447 PRO
edited July 2024 in General
This code should be on multiple lines. It is making it hard to help people @NeilCooke.
FireFox:
FeatureScript 2411;<br>import(path : "onshape/std/common.fs", version : "2411.0");<br><br>annotation { "Feature Type Name" : "My Feature", "Feature Type Description" : "" }<br>export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)<br>    precondition<br>    {<br>        // Input for selecting a sketch<br>        annotation { "Name" : "Sketch", "Filter" : EntityType.FACE }<br>        definition.sketch is Query;<br>    }<br>    {<br>        opExtrude(context, id + "extrude1", {<br>                    "entities" : definition.sketch,<br>                    "direction" : evOwnerSketchPlane(context, { "entity" : definition.sketch }).normal,<br>                    "endBound" : BoundingType.THROUGH_ALL,<br>                    "endDepth" : 1 * inch<br>                });<br><br>        const extrudedPart = qCreatedBy(id + "extrude1", EntityType.BODY);<br>        var targets = qAllSolidBodies();<br>        targets = qSubtraction(targets, extrudedPart);<br><br>        opBoolean(context, id + "boolean1", {<br>                    "tools" : extrudedPart,<br>                    "targets" : targets,<br>                    "operationType" : BooleanOperationType.SUBTRACTION<br>                });<br>    });
  • MichaelPascoeMichaelPascoe Member Posts: 2,447 PRO
    Chrome:
    FeatureScript 2411;
        precondition
    I think it is a copy issue with some browsers. I had to copy it from a chrome Feature Studio for it to work.
    Not wanting to throw @lougallo under the bus, but I’m throwing him under the bus here.
