Import Issues. File is showing two options. UPDATE or DOWNLOAD
null_null3941null_null3941 Member Posts: 17
I often see this after importing a large part from a supplier or Manufacturer.
In this case it is a large file. 2gb. The Translation process notes it has been uploaded and created successfully.
Any help would be much appreciated as i cant view supplied files.
Thanks.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,878
    If it's a 2Gb file (from Rhino? Is it a mesh?) then it will take time to import - check the notifications panel to see when it is "imported" (as opposed to uploaded / saved / created).
  • S1monS1mon Member Posts: 3,430 PRO
    edited August 2024
    @NeilCooke
    This is definitely one of those stumbling blocks as a new user. I've found this painful and confusing and people I've managed needed some guidance as well as they transitioned into Onshape. The feedback is there, but it's not obvious coming from other platforms.
    Perhaps the above text needs to be something like:
    1️⃣ foo.3dm was uploaded successfully. Created at 8:48 AM Today
    2️⃣ foo.3dm translation in progress [███▁▁▁]
    Item 2 needs a progress bar or spinner to make it really clear that something is indeed happening. Right now there's not great feedback.
    Also the call to action at this point of {Update...] or [Download] is weird when there's no part studio(s) or assemblies. Perhaps these shouldn't appear until the translation has completed (successfully or not).
  • null_null3941null_null3941 Member Posts: 17
    HI Neil, Is there somewhere to track its progress? Its now been an hour since I uploaded it and its still not available.
    The model is Solids from Rhino.
    Agree Simon. it would be very helpful as I sat down to check some files from a supplier and it ended up taking over 2 hours to import. If I had known it took so long I could have focussed on other projects.
    An import BAR status with approximate time would be very handy
  • Schoolhouse_StudentSchoolhouse_Student Member Posts: 2 EDU
    hi, i've been having the same problem, but my file is only 106 bytes, and i have been waiting for several days for it to change but it is still showing the same screen. The file i am trying to import is a mesh made in Metashape 3d modeler, but I don't see a reason for that to be the problem. Any answers would be much appreciated.
    @Wylie_Leggett 106 bytes sounds like there's nothing in the file. That's not much room for a header, let alone data. Have you tried re-importing the file into Metashape?
  • cameron_culver458cameron_culver458 Member Posts: 2
    @S1mon What if it says translated?
    Give the document a moment. The part studio will usually show up first, and then the assembly (assuming there is one). If something errors out, you can see that in the notifications.
