Import Issues. File is showing two options. UPDATE or DOWNLOAD
in General
I often see this after importing a large part from a supplier or Manufacturer.
In this case it is a large file. 2gb. The Translation process notes it has been uploaded and created successfully.
Any help would be much appreciated as i cant view supplied files.
Thanks.
Thanks.
This is definitely one of those stumbling blocks as a new user. I've found this painful and confusing and people I've managed needed some guidance as well as they transitioned into Onshape. The feedback is there, but it's not obvious coming from other platforms.
1️⃣ foo.3dm was uploaded successfully. Created at 8:48 AM Today
The model is Solids from Rhino.
An import BAR status with approximate time would be very handy
hi, i've been having the same problem, but my file is only 106 bytes, and i have been waiting for several days for it to change but it is still showing the same screen. The file i am trying to import is a mesh made in Metashape 3d modeler, but I don't see a reason for that to be the problem. Any answers would be much appreciated.
@Wylie_Leggett 106 bytes sounds like there's nothing in the file. That's not much room for a header, let alone data. Have you tried re-importing the file into Metashape?
@S1mon What if it says translated?
Give the document a moment. The part studio will usually show up first, and then the assembly (assuming there is one). If something errors out, you can see that in the notifications.
