How to select an area based on construction lines and points?
w_s856w_s856 Member Posts: 58
edited August 2024 in Community Support
Context: https://cad.onshape.com/documents/07a8eea8e11c894a32335e82/w/31d90610fa2fd2f0b6236488/e/bbba17fc53447835fe37a447?renderMode=0&uiState=66bb1ce00141030b85fcfcd3
I would like to select the red area in this image: https://i.imgur.com/YJRAD0a.png (somehow I cannot just paste the image in the question, sorry for that)
It is delimited by an extruded wall and by two construction lines, I also added a point coincident with the lines and the wall edges. I managed to split the construction line but not the walls edges between the construction lines
My question: how can I select the area delimited by the lines and the wall?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Use normal lines, not construction.
