Countersink below a counterbore?
mark_morgenmark_morgen Member Posts: 12
Is there a simple way to create a countersink hole for a screw that also has a counterbore above it to account for the thickness of the screw head? Take a look at the sectioned hole in the document below to see what I mean. I created a plane 2mm below the part surface, then started the countersink from the plane down into the part and a simple hole from the plane up to the near surface. You have to match diameters of countersink and hole, which could be a problem if you have lots of holes. I'm hoping for an "offset" of sorts in the countersink menu.
Thank you!
https://cad.onshape.com/documents/399d90b9b2899359f33b949a/w/cc2b2aef16335977cd20d1ec/e/722095af3175353e0cc4c324
