Release Management, Finding Released Items
brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
I am using release management on a project at the moment and wondering if anyone has tips on finding released parts within a document. I just want to be able to select the document and surface all the latest releases without having to navigate to the versions. I know I can use the search but you have to know specific part name or number which I don't always have.
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 664
    Hi brucebartlett,
    When you say "finding released parts within a document" are you talking about the version + tab where the released part/assembly/etc is defined or where they are consumed?
    Jake Ramsley
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
    @jakeramsley , I am just looking for a good workflow to find release items within a product structure. I normally like to find stuff by going to my top-level model clicking on items to navigate into the product's structure to find the required details. There is no way that I can see to go from a part or sub-assembly in the top level model straight to the latest approved part or sub-assembly, then to the latest approved drawing, at the moment I have to find the part or sub-assembly, check property details then transfer this into a search at the home screen in another browser tab .
  • adrian_vlzkzadrian_vlzkz Member Posts: 271 PRO
    Have not foung any good/practical way of doing this, I have submitted some enhancement requests. My idea is that there should be a panelsimilar to the Tab managager, but it would be the Release Manager, where it would list the Release and/or Version opened/referenced in the active workspace. That way you could go to your top level assembly and get a full view of status for each component.
    CAD Engineering Manager
    Yes, this sounds like exactly what I want.
    Like in this image when you click the black triangle but it searches through all versions, not just the one you have open and maybe it would also be helpful to have a way to order into product structure, however that may need to be outside of the document to combine items from across documents and released versions.
    One of the ideas that we threw around along those lines was to have have a Release Management Section in the Home page (In addition to Activity, Documents, and Analytics) were you would be able to visualize and/or organize in a central place all your Releases without being on a specific Document.
    I just want to voice my support for development in this area. We're trying to figure out the best way to manage branches, versions, and releases. Better visibility into releases and released parts would definitely be helpful.
    I just found that when you insert a part from a document with releases and click the black triangle it shows a list of all the latest release parts and assemblies and also places the rev level in brackets to the side. I really like this but would like to see a similar way to navigate parts/assemblies/drawings outside of the assembly insert dialogue.
    And would like to see the Revision Number listed not just the Triangle
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 553
    @michael_bromley
    Can you tell me which additional "columns" would be important for you?  I assume you want some sort of search/filter based on certain metadata.
    edited April 2019
    @michael_bromley @adrian_vlzkz @PeteYodis On the insert dialogue the revision is included in brackets after the part number. This seems to be a little different to normal where the part name shows up with no revision.
  • Jeffrey_BaxterJeffrey_Baxter Member Posts: 2
    Getting metadata out of Onshape about released status of materials would be very helpful.
  • david_rubli136david_rubli136 Member Posts: 18 PRO
    I would actualy prefer a list like the Items
    Are there any IR for this topic? If not, we shoul make one.
  • Natan_JackelNatan_Jackel Member Posts: 2 PRO
    Any news on this topic since 2021?
  • S1monS1mon Member Posts: 3,287 PRO
    See List View.
    edited August 2024
    List View was a great step, but still needs a lot of functionality to be more useful.
    Current main limitations:
    -Having to navigate to the corresponding folder of the Assembly
    …Ideally you could search or filter your Documents environment, and see the results in Structure View
    ….-Having to navigate deep into folders feels very counter intuitive in a system like Onshape
    -Only available for Released Items
    ….This renders it useless for early development, when designs are not in Revised State (Only Versions)
    -No Ability to access a Structure/List View from within the Document environment
    ….We need a Panel similar to the Tab Manager to see list/structure views
