Fillet on an assembly between to parts?
ivan_histandivan_histand Member Posts: 4
I must be missing something. I have a simple object: two parts, a cube and a cylinder mated using an assembly. I'd like a simple fillet at the joint, but don't see any way to make this happen. Here's the document:
https://cad.onshape.com/documents/5df57ebb24fc37cb8cdfc3c9/w/75a2ba11a60bcabea1a630fb/e/f0fdcc93cd12a703214d7aac?renderMode=0&uiState=66db3794215f0c02e992824d
I do see this discussion, but no resolution:
  • eric_pestyeric_pesty Member Posts: 2,272 PRO
    This is not what assemblies are for…
    See discussion here:
    https://forum.onshape.com/discussion/25033/stress-raisers-at-intersections-in-assembly#latest
  • ivan_histandivan_histand Member Posts: 4
    Thank you, parts need to be attached and filleted as needed, then assembled, clearly you wouldn't be able to fillet an assembly joint.
  • glen_dewsburyglen_dewsbury Member Posts: 1,098 PRO
    Here is a way to simulate welds and such starting from the assembly using "in context" additions to part studio. Good for getting mass closer to final if there is a lot of welding. Also makes a pretty picture for customers.
    https://cad.onshape.com/documents/e5a84a9bfb292e7a7e073db9/w/eb58a06d60c1358d4fdfa9e1/e/8c9ea4de252e402a9c842a4b
