Routing curve & Control point curve - Introduction of two new features for 3D curve creation
13
    edited September 2024
    So I've read all that I could and watched all the videos about polyline creation. I'm working on a plumbing project and trying to make "route curve" parametric.
    Notes:
    -The "polyline" stores x,y,x locations for points. There are no angles involved.
    -At each point, it does remember the orientation of the manipulator.
    -The relationship between a point, manipulator & mate connect is weird.
    It seems odd that the inputs are called vertex and everywhere else they're called points, I'll call them points:
    At each point, the manipulator orientation is remembered. Rotating the manipulator is an unknown value and not sure it's useful. I hope someone can explain why this is needed:
    "add point on drag" doesn't work if the you've rotated the triad. I usually just reset it and then leave it alone. You can see below it didn't add a point:
    Referencing other points is hard. "relative to previous point" works well. I'm at point 1 so I know I'm working at the beginning of route. Notice that it says "mate connector" for the reference. Notice that the point is highlighted and picking it will change the focus to point 0. When assigning a reference for a point, you can not pick any other points. The change focus overrides your wishes. You always have to pick a mate connector or an external point for a reference, never a point in your route. Notice the point is highlighted and picking it changes to point 0:
    Highlighting the mate connector will allow you to reassign the reference to the start. You could have easily used "relative to previous point" which is usually the preferred referencing scheme. With this approach, all subsequents points are relative to each other and update in a meaningful way:
    This comes up a lot "part of a mate connector" as a reference. I think this should be removed and changed to the mate connector in it's entirety:
    The "previous reference" below is wrong and needs to be assigned to the end point. This is how the route was created. Defining the end of a route is always more challenging. Below is the way the route was built:
    I change the reference to the mate connector defining the end of the route. Notice it's just "part of mate connector". It's the point of a mate connector. Below the offset is based on the last point or the "to" of the route. In all your routes, you have to deal with a "from" and a "to". The "to" is not easy in "route curve":
    So the simple routing above is parametric and will update correctly all day long with any change that'll come along.
    So let's break it.
    It's not hard to break the parametrics in "route curve". Let's remove the diagonal tube and route using ortho path. There are 3 choices, and I want the fewest bends, I choose a path which extends the starting offset:
    "curve reference"
    The world coordinate system is probably the worse system to use. A better approach is to use "curve reference" which establishes all orientations for points. Another way is to be careful and select point 0 correctly. When you have many routes, you'll learn to define a coordinate before starting a route.
    This is the cleanest looking plumbing when everything is in alignment:
    Make a change, I don't think "route curve" will ever be parametric.
    A quick fix, delete the errored point:
    And do it again:
    If you figure out how to make this more parametric, please let me know.
  • Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 117 PRO
    I want to start using the Button Parameter in a feature I just made for woodworking but can't seem to find any documentation on it other then a little note in editing logic function section:
  • Nick_HolzemNick_Holzem Member Posts: 156 PRO
    The final button is missing from CPC.
  • JosefBurjetaJosefBurjeta Member Posts: 30 PRO
    If you're serious about good surface modeling, you'll eventually end up following those rules since it's the only way to achieve good surface quality and final model. 🙂
    When I first learned about them in the university (while working in Alias) I thought I could live without them and do things on my own. It didn't take long and I got back to them, study and understand them. You're not able to produce good surface from terrible inputs as I initially thought. 😁
  • jelte_steur814jelte_steur814 Member Posts: 504 PRO
    I agree, and I did end up following them. but seeing them made explicit and how to work around challenges (e.g. if your surface isn't four sided) is very helpful. I was never taught surface modeling well. I've just learn't it over time.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 336
    Another update today! In this version we ensure that arbitrary periodic curves can now be processed and their degree can be elevated/decreased. I know this issue came up early in some folk's testing, so hopefully you can try it out again on those use cases.
    Today's version:
    https://cad.onshape.com/documents/2c2c376d9979115f9f969a08/v/8d24d6dd5f7ac9587f5d4220/e/929d02bbbb5f71c6176ac653
  • S1monS1mon Member Posts: 3,450 PRO
    Hmmm. I had this 3D curve (degree 9, 9 spans, closed):
    I hit elevate once, and it comes up with this:
    This is not what I would expect.
    I was able to approximate/process a sketched circle and get something useful, but again, elevation is strange.
    Hit elevate once and we get degree 9 with 8 spans:
    Here's what I would hope to see when elevating a degree 8, 2 span closed curve (this was done by changing the approximate/process parameters):
    [edit to add this bug:]
    I'm also noticing that if I approximate/process and change the degree and number of points the resulting degree is adjusted correctly, but the resulting number of spans gets stuck.
    I tried approximate/processing a sketch which is a 180-degree arc and a half-ellipse. The resultant control point arrangement is not exactly what one would hope to see, and the curvature combs are not symmetric like the input curves.
    Here I tried reference edges which are two degree 7 Bridging curves (in a symmetric arrangement). Through trial and error, I found that approximate/process to degree 8 with 16 points got the closest without adding too much wobble, but it's still far from the underlying curves.
    I can understand how the previous test with an arc and elliptical arc was challenging due to them only being G1, but this arrangement of inputs is G3. The result does seem to be symmetric, which is good, but the zig-zagging of the control points is not ideal.
  • STEGSTEG Member, User Group Leader Posts: 125 PRO
    Control over the angle of the manipulator is a must.
    Now that Control point curve is getting better at creating closed curves, Boundary surface's inability to handle closed curves is more frustrating. Clean closed curves are more useful if you can use them to create clean surfaces. Right now you have to split closed curves in order to use Boundary instead of Loft (which turns everything into multi-span degree 3 curves).
    Please vote for this improvement request.
  • Romain_JOUBERTRomain_JOUBERT Member Posts: 2
    What an amazing job ! Thanks !
    In the particular case of piping and tubing (or electrical routings), how would it be possible to add a parameter to keep automatically a given distance from the environment ? I don't even know if it's possible…
  • Jed_YeiserJed_Yeiser Member Posts: 55 PRO
    This may be a small quibble, but I've noticed that control point curve is static once processed. I'm using it to create an approximated spline through a number of edges in a configured design. When I update the configuration, the location of the seed edges change, but the Control curve output does not (until I manually edit the feature and re-process). There are ways around this problem (3D Fit Spline, creating a small/simple approximate spline FS), but It'd be great if Control point curve would update dynamically to take upstream model changes into account.
    It's been some time since the last update. I've been trying to use CP curve for a real project, but the fact that "Process" is not parametric and I need to edit the curve each time the underlying edge changes makes it not really useable.
    With more use, I'm also thinking that having a choice of a "point reference" that is local to the curve, but scales as the chord changes (à la Mutate Curve) would be really nice. Full NUV and/or slide (along the control polygon) movements would be nice, but just to start, it would be great to have the reference be the mid-point of the chord and the average plane through the rest of the CPs.
  • joshtargojoshtargo Member Posts: 381 EDU
    did someone say Mutate?😀
    also, check out my latest script, you may find it useful: https://cad.onshape.com/documents/0c9c1d6da0265651452fb454/w/a19d49c88c42cd1c1f7eecaf/e/511d2a5d9fc7bf0b9382fa4c
    For editing curves created with this, could we have Next point and Previous point buttons so we can work within the UI window, an not have to select points with the mouse?
    edited October 2024
    @GregBrown
    I've been using routing curve as a centerline/skeleton model. The centerline is created in its own document, then derived into a part studio to build off. When referencing the vertex of the routing curve in my model new constrains immediately get added and labeled as "Some external references are missing" This seems to only be a problem while referencing a vertex. I am able to add dimensions from sketch entities to routing curve curve (line) itself.
    I entered support ticket 362847 as I wasn't sure it was related, but now I think it is, hence the post here.
  • md_ar_rahman_dipmd_ar_rahman_dip Member Posts: 18 EDU
    @GregBrown That's indeed a great work. But the triad should also have angle reference. I didnt see any angle can be driven parametrically here.
    Just another quick inquiry- Does onshape have any variable pitch helix?
  • eric_pestyeric_pesty Member Posts: 2,289 PRO
    Check out the "variable helix" FS from CADsharp:
    https://cad.onshape.com/documents/692c433abc951800d638d840/w/0514acf79f73292acbd70beb/e/e53677c83586a66ee9d01961?renderMode=0&tangentEdgeStyle=1&uiState=67292971cac6610c096e9d61
    edited December 2024
    I've been working on this problem for about 2 years and have finally succumbed to a simple solution.
    Solutions tried:
    -morgon's piping script, it's public
    -routing curve the script featured here
    -routing the script I wrote
    -stupidly simple
    Morgon's script is pretty old code but is an amazing piece of work. I do like that a route is defined by a start and end. Routing curve, the one featured in this post, is a great attempt showing a lot of potential. Routing, the one I wrote, looks the simplist of all these but it would only work for 80% of my use cases. And, the problem is, while I could figure out solutions for many routes, no one could ever figure out what made them work.
    My script interface. Start and end how simple is that?
    This is when I gave up writing a routing script:
    180 degree bend and the fs polyline function requires a strait halve way through the bend. Ok, I'm done.
    The solution I've been using, the simplist is the following. I'm working in an assembly and I want to connect the 2 elbows:
    I'm in a partstudio from the assembly and create a sketch defining the orthogonality of my route.
    I create 3 planes:
    I sketch on 3 planes. I know, it's ugly:
    The rest is trivial:
    Back to the assembly and I make a change, actually I make millions of changes:
    It updates!
    I know it's ugly, but it works 100% of the time. I do keep all of the components of a route inside a folder for tidiness and I've converted all my old routes to this simple style. I'm not saying that a fs for routing is a bad idea, it didn't work for me.
    My biggest fear when designing is to create something no one can follow. These single feature routes can be impossible maintain or debug. When you have a parametric project and someone starts to deleting stuff, it'll kill the project and the model you created.
    I'm happy and have all my routings controlled inside an assembly.
    As a side note, I can now fill a computer rack with beer in less than a minute.
  • nick_brown567nick_brown567 Member Posts: 12
    Chris, sounds like your "route curve" parametrics are held together with duct tape and hope
    Two years of battle for a solution that’s ugly but works? Chris, you’ve just invented the engineering mantra
    yeap, kiss
    It was a fun journey and I learned a lot. As an old engineer, not everything works out and that's ok.
    It turns out you can't fillet curves from the standard interface so this weekend I a FS called fillet curve. It'll take a trajectory and fillets (bends in this case):
    The end result now looks like this:
  • wayne_sauderwayne_sauder Member, csevp Posts: 610 PRO
    I agree that the tool needs to be more parametric. I used the routing curve for some tubing work just for fun (some other FS worked better for my case), but as others have stated, it breaks when a change happens in the assembly, and I found it extremely challenging "at times impossible" to fix. There needs to be a way to control the triad angle; otherwise, it's only suitable for freehand work. I also agree that while extremely powerful, it took me a bit of wading around in the UI to accomplish what I wanted.
    Another thing, you have to be able to edit it and maintain it. I'm not saying routing curves are a bad idea, I had a hard time understanding why it they failed and then fixing them. Now I wrote my own router and probably could have improved it, but there were use cases where it just got hard and ugly.
  • Ryan_MeisbergerRyan_Meisberger Member Posts: 1 PRO
    In routing curve, in the XYZ Offset section, could you add the ability to offset until a plane? Similar to the extrude tool's "Up to Face" functionality, the ability to offset the routing curve point up to point would be really helpful. The ability exists to go to a mate connector point reference, but the ability to set the X/Y offset's to 0 and Z offset to "Up to Plane/Point/Mate connector" would be awesome.
  • Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 119 PRO
    edited February 20
    The main bind I'm having with the tool so far is finding it to be way too unresponsive and laggy. It's slow dragging the points around to the extent that it is almost unusable and instead considering doing annoying workarounds like intermediary 2D sketches connected by bridging curves and joined with the composite curve. Is anyone else finding this to be the case too? It would be quicker for me to go into a clean modeller like Rhino to draw the curve after STEP exporting from onshape where I want to draw curves between and then import back. I can't understand the behaviour of clicking to add a vertex, it being temporarily listed, and then disappearing from the list. What is the meaning of this temporal nature of the vertices list?
    Jonathan, thanks for the feedback and continued interest in this feature… Firstly, how many points are in your Routing curve array? Does it become too laggy after a certain number of them, or is your comment a general one.
    As my own "general" comment, we are doing a lot of work on this feature, and despite not having shared any updates since the first 11 updates we made following the Custom feature's launch last year, we've been addressing many of the issues that have been raised in this thread. Much of it with usability of the manipulator, point creation,/referencing, but also much more. I hope to share details about this shortly. Rest assured your feedback has been heard, appreciated and invaluable. Please stay tuned.
