How on earth do you grab and move drawing geometry
michael_fuller
Member Posts: 27 ✭✭
I simply want to grab and move drawing geometry (related lines and circles, etc.) within a sketch. Simple stuff, but I cannot figure out at all how to do this.
1
michael3424
Member Posts: 751 ✭✭✭✭
If the sketch entities are black, then they are constrained to something and you won't be able to drag them around. Entities that are blue are unconstrained and you should be able to move them around so long as you are in edit mode for the sketch. To remove sketch constraints, edit the sketch and check the box for "Show constraints". That will reveal each of the constraints and you can delete those that you don't want by left clicking on them (to select them) and hitting the delete key on your keyboard.5 -
NeilCooke
Moderator, Onshape Employees Posts: 5,933
You can also use Transform (select geometry, right click)Senior Director, Technical Services, EMEA2 -
heider_sati
Member Posts: 4 ✭
You can do this in 2 ways:1) Select the vertices (dots) NOT lines of your sketch, once all are selected, drag one of them, it should move the rest. Or;2) More from an "engineering" perspective; drag to select your sketch, right-click and then select "Transform" you should see the arrows to move X, or Y, Scale or Rotate altogether.I hope this helps,Kind RegardsHeider0
Do you literally mean on a 2D drawing, or in Sketcher?
In a drawing. I have a title block (custom template) that I need to move slightly. So a large group of text objects and lines that need to move about 3mm to align with the drawing border. Seems like a trivial task, but nope. Apparently impossible?
Same here, and the "good" answers, to remove constraints or transform .. are not at all simple to use.
Folks, this is ridicilous, this software claims to be easy to use, and the most basic, straitforwarward idea (back from Xerox labs) to move the mouse cursor, click and drag an edge or part - does not work.
Right click a line - no "transform" function is mentioned.
After finding the transform icon, and activating it - no selection of my line is possible.
Then, "Show constraints" is marked - but where ary they?
What happended in the heads of the developers to sell us this .. convulted mess?
Sorry …😒
