New FeatureScript: Thread Creator
13»
  • trevor_brinstontrevor_brinston Member Posts: 2
    Just wounding is there a constant method for picking where the thread starts?
  • TheNorthernLightTheNorthernLight Member Posts: 3
    Just thought I'd come along and say that this script is awesome! Saved me a ton of time and effort. Only wish: If it could have an option for less rotations for the same length (allowing for faster on/off, with less clamping force as the side effect). I know there is a term for this, but I cannot remember what it is officially called.
  • martin_kopplowmartin_kopplow Member Posts: 1,219 PRO
    Do you mean the term "pitch"? Pitch is defined as lengthwise progess per rotation. A greater pitch value will result in less rotations of the thread grooves around the cylinder for a given length.
  • jacob_nicolle663jacob_nicolle663 Member Posts: 2
    9 years later and this is still amazing and unbelievable its not a standard feature!
  • david_dawson936david_dawson936 Member Posts: 2
    9 years & 2.5 months later …… ^ What jacob said. Awesome feature - thank-you.
  • josé_rodrigues849josé_rodrigues849 Member Posts: 2
    Hey, still a good tool !
    However, I do have a quick question: Is there a way to change the "tolerances" of the threads ? I tried using the thicken tool, but it won't resolve.
    Cheers
  • cplane_bdronecplane_bdrone Member Posts: 2
    This made my music load when i used this tool🤣
