added a image onto one of my parts but does not show in assembly or drawing
dan_schniersdan_schniers Member Posts: 16 ✭✭
i have added a image onto one of my parts that is in a assembly, the image will show up on the part but does not show on the assembly or the drawing is there a setting that can fix this.
Thank you
Dan
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
    No, you can only view this images in the part studio, it will not link to the assemblies and drawings.
    You can, however, import images to drawings independently if this helps but it will not be link to a view.
  • sean_barringersean_barringer Member Posts: 2
    there is a sticker overlay in the render studio but i cannot figure out how to use an image.
  • GWS50GWS50 Member Posts: 446 PRO
    You can however use the Decal Tool which is under the Transform Tool Drop Down.
    This will show up in a drawing but you you need to set the viewport to show Shaded View
