How to limit rib length
amir_livne
Member Posts: 85 ✭✭
Hi
Is there any way to limit Rib length
Attached picture
Thanks
Amir Livneh
It’s probably easier to just use an extrusion instead of a rib in that case.
Thank you, but I cannot accept it
Why?
In that particular case it may give an answer but in case of cylindrical part it will be a problem.
More then that - as a teacher I'm teaching my students to use the right feature in the right place and here we have a problem.
You can fix this by changing the sequence, however you my want to report this as a bug to avoid having to go back and fix problems.
You could also add a split face and delete face after the fact…
Not ideal but dealing with unexpected results/limitations should also be part of teaching (and that's a good workflow to know anyway)!
Hi
I found a way to cope with that problem/
I just move the rib before the cone
