Perpendicular Vector
graham_lock
Member Posts: 262 PRO
Hi
I'm drawing a sketch line on a plane which has its own coordinate system:
const lineEndPoints is map = skLineSegment(sketch1, "line1", {
"start" : vector(0, 0) * meter,
"end" : worldToPlane(sketchPlane, vector(dist.sides[0].point[0] / meter, 0, dist.sides[0].point[2] / meter) * meter) // point[0] is x, point[2] is y
I then need to draw a rectangle of a given size which has 2 edges perpendicular to that line, positioned at one endpoint, similar to:
I've been experimenting with perpendicularVector but haven't found how to make it work.
If this is the correct approach a quick example of its use in this use case would be greatly appreciated.
If this is not the correct approach how should I go about it?
Thank you.
NeilCooke
Moderator, Onshape Employees Posts: 5,926
perpendicularVector is for 3D vectors and there's no guarantee that it will be on your sketch plane.
Best to do all the vector math outside of the sketch, draw the rectangle at the origin then transform it.
FeatureScript 2473; import(path : "onshape/std/common.fs", version : "2473.0"); annotation { "Feature Type Name" : "My Feature", "Feature Type Description" : "" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "X" } isLength(definition.dx, LENGTH_BOUNDS); annotation { "Name" : "Y" } isLength(definition.dy, LENGTH_BOUNDS); } { const lineStart = vector(0, 0) * millimeter; const lineEnd = vector(definition.dx, definition.dy); const lineLength = norm(lineEnd - lineStart); const lineAngle = (definition.dy < 0 ? -1 : 1) * acos((lineEnd[0] - lineStart[0]) / lineLength); const angleTransform = matrix([[cos(lineAngle), -sin(lineAngle)], [sin(lineAngle), cos(lineAngle)]]); const boxWidth = 2 * millimeter; const boxHeight = 1 * millimeter; var rectangle = [vector(boxHeight, boxWidth), vector(-boxHeight, boxWidth), vector(-boxHeight, -boxWidth), vector(boxHeight, -boxWidth), vector(boxHeight, boxWidth)]; for (var i = 0; i < size(rectangle); i += 1) { rectangle[i][0] += lineLength; rectangle[i] = angleTransform * rectangle[i]; } const sketch1 = newSketchOnPlane(context, id + "sketch1", { "sketchPlane" : XY_PLANE }); skLineSegment(sketch1, "line1", { "start" : lineStart, "end" : lineEnd }); skPolyline(sketch1, "polyline1", { "points" : rectangle }); skSolve(sketch1); });Senior Director, Technical Services, EMEA1 -
NeilCooke
You're over complicating it 😊 just do it in 2 sketches:
Senior Director, Technical Services, EMEA0
FeatureScript 2473; import(path : "onshape/std/common.fs", version : "2473.0"); annotation { "Feature Type Name" : "My Feature", "Feature Type Description" : "" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "X" } isLength(definition.dx, LENGTH_BOUNDS); annotation { "Name" : "Y" } isLength(definition.dy, LENGTH_BOUNDS); } { const lineStart = vector(0, 0) * millimeter; const lineEnd = vector(definition.dx, definition.dy); const lineLength = norm(lineEnd - lineStart); const lineAngle = (definition.dy < 0 ? -1 : 1) * acos((lineEnd[0] - lineStart[0]) / lineLength); const angleTransform = matrix([[cos(lineAngle), -sin(lineAngle)], [sin(lineAngle), cos(lineAngle)]]); const boxWidth = 2 * millimeter; const boxHeight = 1 * millimeter; var rectangle = [vector(boxHeight, boxWidth), vector(-boxHeight, boxWidth), vector(-boxHeight, -boxWidth), vector(boxHeight, -boxWidth), vector(boxHeight, boxWidth)]; for (var i = 0; i < size(rectangle); i += 1) { rectangle[i][0] += lineLength; rectangle[i] = angleTransform * rectangle[i]; } const sketch1 = newSketchOnPlane(context, id + "sketch1", { "sketchPlane" : XY_PLANE }); skLineSegment(sketch1, "line1", { "start" : lineStart, "end" : lineEnd }); skPolyline(sketch1, "polyline1", { "points" : rectangle }); skSolve(sketch1); });Thank you so much for the example - exactly what I was looking for.
@NeilCooke
Hi @NeilCooke,
I've integrated your example into a test document and it does exactly what I asked for, the box profile follows the edge of the curved face and is perpendicular to the line.
Could you suggest the best way to make the profile follow the line as currently but be oriented such that it is tangent to the curved edge please?
https://cad.onshape.com/documents/5ae9b4531272e0d2f135073c/w/bc3f6ab2b17a961efef1b4fd/e/14315dad3efc51b9f4fe8227
Thank you.
https://cad.onshape.com/documents/6232edc86fa5b3933c9cc699/w/8a4b0f15bb93348c33e3d313/e/993f98802348cecb6d0640f2
Thank you - that's very clean.
Hi,
I inadvertently marked the original question as answered and couldn't see how to unmark it - is there a way?
To continue with the help provided by @NeilCooke …
I've created a test document which allows switching between tangential and perpendicular tracking.
This has generated another question:
line 126:
boxPlane = plane(edgeTangentLine.origin, -Y_DIRECTION, edgeTangentLine.direction);
to
boxPlane = plane(edgeTangentLine.origin, Y_DIRECTION, edgeTangentLine.direction);
but then spline generated curves are incorrectly calculated?
https://cad.onshape.com/documents/a210980f37f6eb8934643f1d/w/c438d98168a82355ea5d0764/e/f4d243419a7ec6ec132347ac
Any further help appreciated.
Thank you.
