Force radius or diameter dimension in a sketch
Say I've sketched what will be a hole and add a keyway to the sketch. After trimming away a portion of the original circle I want to dimension the diameter. Because it is now not a closed arc, OS will only let me dimension it as a radius. But I want the hole to be dimensioned as a diameter. Am I missing something, or is there no way to force a radial dimension to be either a diameter or a radius?
Brian
Brian
viru Member, Developers Posts: 619 ✭✭✭✭
@brian_brady,Currently this facility is not available in Onshape. You can raise improvement request for this. In near future we hope that this facility will be definitely provided by Onshape.
5
As for sketch, I would divide my features, as the hole as a hole in a first feature and then the key in a second feature using extrude(remove) tool.
Hope this helps
Brian
_Ðave_
Well, it has been 8 years @viru , does the facility exist yet? This is a very important and simple feature of parametric modeling, designers must be able to control either a radius or a diameter.
