Distances between points and/or parts on Assemby Studios
gonzalo_chomon
OS Professional Posts: 56 ✭✭✭
Althought the program tells you distances and other information between diferent instances on Part Studios, I miss similar information on Asembly Studios.
When designing parts, not always are located on the position that will be located when asembled or can be assembled on different ways... So sometimes I need some infromation about distances between parts or certain points on the assembly. (May be it is only me...)
So I think that will be very usefull for me a tool that tell the designer the distances between determined points when assembling
May be the points can be determinated by mate connectors points.
Does any other think this tool will be usefull?
I have opened IR for voting,
https://forum.onshape.com/discussion/1728/measurement-between-mateconnectors-in-assembly-mode
