How to lof this
nyholkunyholku Member Posts: 60 PRO
I'm trying to model following with loft, it is a feature on an engine oil pan. I'm trying to use the yellow line as the guide, but it won't generate. If I replace that yellow line (which is a line+arc) with a single arc or single line then then loft generates using that as a guide.
So what are the rules here, how should I create the guide line or how should I model this.
  • shanshanshanshan Member Posts: 147 ✭✭✭
    yes, there is a rule here, now we can not choose any guild  which includes lines and arcs and so on , but when you are drawing the guide, you can use "spline" here,we can choose any spline as guide line
    edited September 2015
    @kustaa_2 : actually you can use a string of lines and arcs as a guide curve in Onshape, provided:
    1) the endpoints are constrained coincident (it is not enough for them merely to occupy the same location)
    2) there are no other entities in the sketch (other than points and construction lines)
    3) you must select the sketch from the feature list. The loft will not be created if you choose the entities from the graphics window. In other words, it must show in the "guide curves" list as "Sketch x", not "edges of Sketch x"
  • nyholkunyholku Member Posts: 60 PRO
    Thanks! The 3rd rule was golden! Now it lofts beautifully...
    Tool tip material, thanks @andrew_troup
    andrew_troup said:
    actually you
    @andrew_troup , thank you! for valuable point
    andrew_troup,I did not notice that we can select the guide lines from feature list, Onshape has updated it!your points about loft are valuable, thanks very much!
