[ANSWERED] Create lobed knob / Sweep along "wavy circle"
felix_fischer992felix_fischer992 Member Posts: 7 EDU
edited October 2024 in Community Support
Document with all the tries in separate part studios: https://cad.onshape.com/documents/7d92ebfc4d42d67498b44c02/w/c3e079a016e5604e415d2895/e/8d83e605f9727daac7ef5c4f?renderMode=0&uiState=671eb1542b083d3d38a744a6
Any help on this would be greatly appreciated.
It is kind of tricky to put into words what I want to create, so here are two pictures of the kind of knob that I want to model:
Mafell-Multifunktionsanschlag-MFA-zuschaltbare-Winkelrastung-Erika-70-85-207910-1.jpg
My initial idea was to sketch the circumference using straight lines and arcs like so
…then thicken the core and sweep a semicircle along the outside perimeter.
This however only succeeds if I select three or less segments of the perimeter, otherwise the Sweep won't work and say "Lock direction causes invalid geometry" (even though I never selected lock direction anywhere.
I was able to kind of get what I wanted by separately sweeping the straight section, then a curved one and cutting off the "excess". The result of which I could put in a circular pattern.
This does seem like a very odd way of doing it, though.
  • rick_randallrick_randall Member Posts: 417 ✭✭✭
    edited October 2024
    @felix_fischer992 - You might try this approach, revolve the basic round form, sketch necessary geometry required to cut one flute, sweep cut that shape one time , then circular pattern that sweep cut feature (don't forget to check the apply all instances box)
    Good luck
  • jelte_steur_infojelte_steur_info Member Posts: 655 PRO
    edited October 2024 Answer ✓
    I would always strive to create only one section of this geometry, cutting off excess if required, and putting that in a circular pattern. that is definitely the way to go.
    That way if you add a fillet to the edge, Onshape only has to calculate that once and can just copy afterwards.
    perhaps a loft with a path is the way to go for spanning the gap between two 'straight' sections.
  • felix_fischer992felix_fischer992 Member Posts: 7 EDU
    Thanks a lot, that works a lot better and produces a result that is close enough to what I want.
    I don't think it is perfect yet, since the knob in the pictures looks a little different, but it will certainly do for my purposes!
    Here is an example,
    https://cad.onshape.com/documents/61ec28e939a493243b3f4f9d/w/17a712bc57cb3c92624aa976/e/72f12b5c1a5344ae2bac4379
    I didn't spend much time on this, and finished form should probably be adjusted (but it demonstrates the workflow).
    Tank you for the example, I didn't quite understand your approach before but now it is clear to me.
    This looks like the best way of doing it.
