Improvements to Onshape - November 1st, 2024
NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,991 image
edited November 2024 in New in Onshape
PART STUDIOS
THICKNESS ANALYSIS
A new analysis function enables designers of molded and die cast parts to measure how much material is distributed throughout each region of a part. Only native Onshape parts and mesh model types are supported at this time. Thickness analysis is currently only available for Onshape Enterprise users, but will be available for Onshape Professional and Onshape Education Enterprise users in the near future.
https://onshape.wistia.com/medias/wx5orn26am?embedType=async&seo=true&videoFoam=true&videoWidth=1280
SHEET METAL CORNER BREAK
The new Corner break feature combines Fillet and Chamfer features to remove sharp edges on sheet metal corners and corner / bend reliefs.
https://onshape.wistia.com/medias/6lqpuulmfk?embedType=async&seo=true&videoFoam=true&videoWidth=1280
EDIT CURVE
A new Edit curve feature allows you to edit an existing curve by selecting sketch entities or curves to apply a simplified approximation, elevate the degree, reposition control curve vertices, and/or planarize into any 2D plane and all downstream features update automatically to reflect these changes.
https://onshape.wistia.com/medias/ina49gqtsk?embedType=async&seo=true&videoFoam=true&videoWidth=1280
DIMENSION ENTITY HIGHLIGHTING
Adding dimensions while sketching is now much easier to visualize.
https://onshape.wistia.com/medias/0mjgjasjid?embedType=async&seo=true&videoFoam=true&videoWidth=1280
DRAWINGS
HOLE CALLOUT TEXT JUSTIFICATION
Hole callouts on a Drawing now provide more control over their appearance.
https://onshape.wistia.com/medias/qi9mr5f327?embedType=async&seo=true&videoFoam=true&videoWidth=1280
DOCUMENTS
STRUCTURE VIEW
Structure view on the Documents page is now available for all Onshape Professional users. As a reminder, here is an overview of this great feature for navigating released product designs.
https://onshape.wistia.com/medias/j10e5r2594?embedType=async&seo=true&videoFoam=true&videoWidth=1280
GENERAL
CUSTOM KEYBOARD SHORTCUTS
All commands in Part Studios and Assemblies can now be assigned custom keyboard shortcuts.
https://onshape.wistia.com/medias/k2kmonas8m?embedType=async&seo=true&videoFoam=true&videoWidth=1280
ACTION ITEMS
The Action items user interface has been reworked to make it easier navigate.
https://onshape.wistia.com/medias/8q4hc1oo2f?embedType=async&seo=true&videoFoam=true&videoWidth=1280
FEATURESCRIPT
PERFORMANCE
The latest standard library removes the performance overhead of many of the FeatureScript wrappers around builtin functions.
RENDER STUDIO
DECALS
Decals added to a Part in a Part Studio are now imported as an Appearance in Render Studio.
https://onshape.wistia.com/medias/0f3wnplkbj?embedType=async&seo=true&videoFoam=true&videoWidth=1280
ISOLATE
New Isolate option for Render Studio Parts, Part Studios, or Assemblies. Right-click on one or more entities and select Isolate from the context menu.  When Isolate is selected, all selected entities are viewable and all other entities are hidden in the graphics area.
RESOURCE VERSION INDICATOR
Resources, such as images used for backgrounds, now have a resource indicator to let you know if they are current or require an update.
RESET ALL TESSELLATION
A new Reset all tessellation option, available from the top-level Render Studio in the Scene list, allows you to reset any custom tessellation settings for all entities below back to Auto.
«1
  • rick_randallrick_randall Member Posts: 417 ✭✭✭
    Sheet metal corner breaks, edit curves, and custom keyboard short cuts - Oh boy, have I been waiting a long time for these. Big time release guys, can't wait to try them out.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,635 PRO
    Juicy!
    That edit curve looks good, especially the part where it keeps the curve ID! I'll have to try that one. Decals in render studio are going to be a big help (anyone who's tried to apply them directly within render studio will know what I mean!)
    There are also two lines in the changelog that appear to be aimed specifically at bugs that we have been struggling with so I have high hopes these are going to be fixed!)
  • aeromorrisonaeromorrison Member Posts: 81 PRO
    Great release! I'm excited about dimension entity highlighting (great quality of life improvement), edit curve, structure view, and sheet metal corner breaks.
  • jelte_steur_infojelte_steur_info Member Posts: 655 PRO
    Wow! great release. major functionality between the tickness analysis and edit curve feature.
    I completely agree with @S1mon that thickness analysis should also come to Onshape Standard. Just like draft analysis, it's kind of a must-have feature for a basic CAD system. A hygiene factor one could call it.
  • andrew_kelly561andrew_kelly561 Member Posts: 4 PRO
    great load of new improvements. Quietly doing a dance here.
  • martin_kopplowmartin_kopplow Member Posts: 1,317 PRO
    Great Update! The first ones I'll have to investigate deeper are certainly Curve Edit and the Structure View. I think there's quite some potential in these.
  • MDesignMDesign Member Posts: 1,337 PRO
    The curve edit is gonna help me tremendously with my work regarding scan data. Wondering if it would be possible to add the ability to add/remove singular control points on a curve? Some sort of number displayed next to the points in the graphical area would help to know which points I'm editing, that way if I need to delete an override or change it, I know where in the list that override is. Also it would be more handy for me to work with the curve points via spline vs bezier since I'm trying to match scan data. Then I can just get the points as close to the mesh as I need.
  • maciekmaciek OS Professional Posts: 35 PRO
    Finally, the wall thickness analysis. My company was waiting for it for few years. We make parts for injection molding, this feature is critical for us. Thank you for that feature. When will it be available in Professional licence?
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 994 ✭✭✭✭✭
    Sheet metal corner break! nice work Onshape!
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • JimEChandlerJimEChandler Member Posts: 1 ✭✭
    Thank you!! I was just working on a project with a decal in Render Studio.
  • Lucas_KuhnsLucas_Kuhns Member, csevp Posts: 105 PRO
    Very happy about the customizable keyboard shortcuts!
  • GWS50GWS50 Member Posts: 500 PRO
    Great Update, but I can't seem to filter the Structure View to just one document….I get everything!
    Sheet metal and Keyboard Shortcuts are just fab though as is the Curve editing.
    Thank you Onshape
  • Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 122 PRO
    CUSTOM SHORTCUTS WOHOOOOOO!
  • Nick_HolzemNick_Holzem Member Posts: 210 PRO
    This update is mass banging! Can you top it next realease? keep it rolling!
    @GregBrown curve tweaker was far more fun to say than edit curve 😉So happy to see this one come through and with more tools. I'm excited to see try planarize in my designs.
    Please continue to review our old requests. I think there are many simple small improvements everyone would benefit from. Non global Point to Plane measurements in assemblies, improve drawing table management and function, improve configuration table management, sketch constrain manager, better assembly mate naming, improve curvature analysis tool with final button to name a few.
    …just made to change log. Quite a few fixes that sound like familiar issues. Will check them over next week 😃Thank You
  • ben_partouchben_partouch Member, csevp Posts: 160 PRO
    Impressive. Thank you Onshape team!
  • joshtargojoshtargo Member Posts: 495 EDU
    Full Custom keyboard shortcuts is fantastic.
    Some good quality of life and usability improvements here.
    I feel like Onshape is due for a bit of a feature freeze, and spend a solid few months banging out some old but fundamental Improvement requests.
    I've come across a few from as far back as 2015 that are basics for a CAD system, but still not implemented.
    Although a rebuild of the drawings package instead of continuing to mod what you bought would be one I'd like to see. The impression I get is it's getting left behind because of the structure of it that makes it more difficult to implement improvements.
    Some what related:
    I did the survey monkey sirvey for you recently, but what wasn't in there (understandably) but would be very valuable for you is why DIDN'T you choose OnShape. Or at least what misgivings you had about adopting it that would've made your decision easier.
    Bugginess requiring work arounds and half broken basic funcrionality was definitely the biggest weak point of on-shape. The thoroughness and responsiveness of your customer support won us over in-spite of it.
    The only thing better than a fantastic support team is a product that doesn't need support.
    If you can eliminate the drawbacks if what exists, that'd do more for us (and your growth) than shiny new headline features.
    @josh_targo it was emailed out. It's an indivisual specific link
  • SebastianMaklarySebastianMaklary Member Posts: 29 PRO
    Awesome with the corner break! Being unable to add fillets to the edges of a chamfer and being able to fillet the bend relief are needed features that I just as soon as last week pointed out to our new employee as being some wierd restrictions with sheet metal in onshape.
    I'm happy to see those restrictions removed.
  • JosefBurjetaJosefBurjeta Member Posts: 30 PRO
    There's definitely a lot of useful updates.
    Thickness analysis is a must, I do hope for other users to will have this tool available. I have to say it came a long way from early testing and there's huge improvement in time to finish analysis. Now it's more bearable, but if you have some other tweaks in the sleeve, feel free to speed it up even more. :)
    Edit curve - it become really nice feature from Routing curve and Control point curve. Will need to test it properly, but it looks promising and easy to use. I would like to highlight this feature will not create a new curve, but only redefine old one. That's awesome! It would definitely be nice to propagate this approach to all features in Onshape. That will lead to more robust designs. Currently for example Extrude will create a Part 1, in the dialog box there's "Faces of Sketch 1" not just Sketch 1. And if you select something else as input, the output Part 1 is different from the first one.
    Dimension entity highlighting is nice, useful feature. It would help while rotating the part.
    Custom keyboard shortcuts - nice, but I'm still missing "Move rollback bar up/down" and Roll to end/here. Can you look into that as well?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,061 PRO
    good stuff.
    The additional keyboard short cuts are nice but, how come you still haven't let us bind deselect all into the ESC button?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,991 image
    @JosefBurjeta if you click the rollback bar so it turns blue, you can use the cursor up/down butttons.
  • shawn_crockershawn_crocker Member, OS Professional Posts: 963 PRO
    Sheet metal corner break looks nice! I linke to see that geometry features are starting to make there waying into the flat patteren editing space. I am also very intrigued to start testing out render studio for the performance improvements. Recently, render studios performance for me, has been nearly unbearable and I had basically abandoned it simply because I already have way too many grey hairs! 😄
    @NeilCooke I'm aware of that, but it would definitely be nice to have the option for keyboard shortcut for that. No need to move cursor to the tree and keep it in the 3D space.
    Same goes for Roll to here & Roll to end. It would be really cool if you could highlight feature in a tree, use keyboard shortcut and have the Rollback bar be moved under such feature. I do realize it will be complicated, but using keyboard shortcuts is way faster than RMB menus. :)
