How to lof this
nyholku
Member Posts: 60 PRO
I'm trying to model following with loft, it is a feature on an engine oil pan. I'm trying to use the yellow line as the guide, but it won't generate. If I replace that yellow line (which is a line+arc) with a single arc or single line then then loft generates using that as a guide.
So what are the rules here, how should I create the guide line or how should I model this.
1) the endpoints are constrained coincident (it is not enough for them merely to occupy the same location)
2) there are no other entities in the sketch (other than points and construction lines)
3) you must select the sketch from the feature list. The loft will not be created if you choose the entities from the graphics window. In other words, it must show in the "guide curves" list as "Sketch x", not "edges of Sketch x"
