Thin Feature and Open sketch extrusion
in General
Is the Thin Feature and Open sketch is part of the Onshape direction?
I've tried creating a surface and thicken, but it does not thicken symmetrically. Not the same thing.
Thin feature extrusion is part the OnShape direction?
But I could not hide the surface. Where is the click to hide surface?
Look closely at the two screen shots
To expand the "Surfaces" portion of your parts list, you need to click on the sideways arrowhead so it becomes an inverted chevron and displays the surface or surfaces individually, as in @philip_thomas' screenshot
Since I have your attention how about a thin extrusion and open sketch extrusion.
We have some methods available to create thin features using surface options but above provision could also be enhancement since it doesn't need to create any surface.
