Sketch dimension text
Jim_FifeJim_Fife Member Posts: 7
Is it still true that you cannot add text to a dimension in sketch mode? Like when I have 8 concentric diameters to dimension, I can't put "flange nut b.c." and "pitch CL" on respective dims, to tell them apart?
  • robert_scott_jr_robert_scott_jr_ Member Posts: 696 ✭✭✭
    Not sure if this will help you but if you use variables for your dimensions the name of the variable will be displayed when you hover over the dimension. - Scotty
  • Jim_FifeJim_Fife Member Posts: 7
    Text supporting a dimension callout in a sketch is a vital part of keeping good engineering notes as you design. SolidWorks does this; Onshape does not (I guess). This is a real drawback to the program.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,471 PRO
    There is a bit of a workaround if you use the comment syntax:
  • ryan_mcgoldrickryan_mcgoldrick Member Posts: 71 ✭✭✭
    Is this an improvement request yet? was just trying to do this again been years of missing it now from solidworks.
    haha yes I raised the first improvement request for it in 2020.. go up vote it here: https://forum.onshape.com/discussion/14492/add-text-to-dimensions-in-sketch
