Fillets on internal corners
graham_lock
Member Posts: 265 PRO
Hi,
I have bodies which look like this:
I'm trying to workout how to find the internal corner edges so I can apply fillets?
I'm using qSmallest(qOwnedByBody(body, EntityType.EDGE)) (is there a better way?) which returns all 8 corner edges but how should I filter the inner ones?
Any help appreciated.
Thank you.
lana
Onshape Employees Posts: 755
You can use evEdgeConvexity for the edges, You are interested in concave edges.
2
You could look at the code for selection fillet, or just use the custom feature.
Thank you for your reply.
I now have the following:
for (var edge in evaluateQuery(context, qSmallest(qOwnedByBody(outerSplitBody, EntityType.EDGE))))
if (evEdgeConvexity(context, {
"edge" : edge}) == EdgeConvexityType.CONCAVE)
debug(context, edge);
println("Found internal edge");
This does indeed find the internal edges - is this your intended approach?
Thanks @S1mon i’ll take a look at that.
@graham_lock
Yes - that looks correct.
