ARM64 Support - Snapdragon X Elite
Member Posts: 2 EDU
Is onshape offically supported on ARM64 as opposed to x86? I see one forum post suggesting that some sketch/selection? functionality might not work. If not then I will not take the risk buying an ARM laptop.
  • Moderator, Onshape Employees Posts: 5,836
    As long as your browser supports it, we do.
    You can always try it in the store before you buy.
  • Member Posts: 429 EDU
    It runs just fine on my Raspberry Pi 5
  • Member, Onshape Employees, Developers Posts: 402
    Every Onshape developer is running an ARM laptop. @NeilCooke is right. If you have a browser that works, Onshape will too.
  • Member Posts: 2 EDU
    Great, thanks for the info!
    @parker_bradshaw589 please hold off on your purchase. Two different people reached out to me internally and pointed out that there is an open issue with Snapdragon(R) X Elite - X1E80100 and Onshape.
    I'm not sure if it's something that we are going to be able to fix or if it's an issue with the Snapdragon.
    My apologies for the incorrect information!
  • OS Professional Posts: 26 PRO
    any news? I just bought the Microsoft Surface Laptop with Snapdragon X Elite 😑
  • Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,011
    @maciek What exactly doesn't work? Does the in-document canvas (3D area) not work when you open a document? Are you running Chrome or Firefox? Are you trying to use flags or overrides to force webGL to load? Send some details and I can reach out directly to see what else might be in the mix.
    Just have a look - https://streamable.com/rzngp2
  • Member, Onshape Employees Posts: 583
    An issue has been identified. Fingers crossed that it will be resolved in the next release.
  • Onshape Employees Posts: 65
    With Onshape release 195 we believe we've resolved the selection issues on the Snapdragon X Elite GPUs. We were getting garbage data back from the tiny pick buffer we use to support selection. We've applied a work-around and have seen the issue improve. Please let us know if you find the issue is not resolved.
