Improvements to Onshape - November 22nd, 2024
NeilCooke
NeilCooke Posts: 6,097 image
edited December 2024 in New in Onshape
PART STUDIOS
FLATTEN SURFACES
Flatten surfaces is a new Analysis tool that generates a planar surface from one or more contiguous non-planar surfaces. This is useful to evaluate the flat (cut) shape for a paint mask, decal, or text curves. The result can be exported to PARASOLID, STL, DXF, or SVG file format.
https://onshape.wistia.com/medias/nr3mfu1m58?embedType=async&seo=true&videoFoam=true&videoWidth=1280
PAUSE REGENERATION
Part Studio regeneration can be temporarily paused while multiple configuration, variable table values, or feature parameters are modified.
https://onshape.wistia.com/medias/5v1garobzl?embedType=async&seo=true&videoFoam=true&videoWidth=1280
SKETCH PROFILE INSPECTOR
Tiny gaps between sketch entities are difficult to detect, especially in complex imported DXF files. The Profile inspector, a new sketch diagnostics tool, quickly finds all the open ends of non-construction geometry.
https://onshape.wistia.com/medias/dv93jx8ca1?embedType=async&seo=true&videoFoam=true&videoWidth=1280
SKETCH BEZIER CURVE
Elevating the degree of a Bezier sketch entity increases the number of control points while maintaining the exact geometry. Lowering the degree reduces the number of control points, preserving the geometry where possible and approximating the geometry as closely as possible when exact geometry cannot be maintained.
THICKNESS ANALYSIS
Thickness analysis is now available for Onshape Professional and Onshape Education Enterprise users.
DRAWINGS
PASTE AS TABLE WITH FORMATTING
Tables created by pasting cells from Google Sheets or Microsoft Excel now import text styles (font size, bold, italic, underline, strikethrough) and cell width and height. Note that if a style is applied to only part of the cell text, it is not preserved.
RELEASE MANAGEMENT
ADDING OBJECTS FROM OTHER DOCUMENTS
Onshape Professional users can now add parts, assemblies, drawings or files from other documents to a single release candidate and release them together.
https://onshape.wistia.com/medias/vur04lyhsi?embedType=async&seo=true&videoFoam=true&videoWidth=1280
RENDER STUDIO
LEGACY RENDER STUDIO BETA TABS ⚠️
Render Studio was officially released in Onshape 1.181 (May 17th, 2024). Access to the beta version of Render Studio will cease on February 29th, 2025 and all exisiting Render Studio beta tabs created prior to the official release will be automatically deleted on this date. Only rendered output created from those tabs will remain.
SELECT MATCHING INSTANCES
All instances of the same part or subassembly can now be selected by right-clicking and choosing Select matching instances, regardless of where they appear in the assembly structure.
ISOLATE TRANSFORMS AND PROJECTORS
All entities added to a Transform or Projector can now be isolated on screen with a simple right-click.
MOBILE
MERGE LINES ON iOS
Merge lines can now be displayed on an iOS device for a clear high-level overview of the development timeline.
LEARNING CENTER
CERTIFICATION
The Onshape Learning Center has upgraded the certification experience. Both exams are now fully embedded in the Learning Center and do not require navigation to a separate testing platform. The Certified Onshape Associate has also been upgraded with completely new data sets to test your CAD knowledge.
API QUICKSTART
Building off of our previously released Introduction to the Onshape API course, we have now added an Onshape REST API Quickstart video explaining how to create a simple application for personal use.
«1
  • joshtargo
    joshtargo Posts: 645 EDU
    great new additions, especially the sketch improvements!
  • EvanReese
    EvanReese Posts: 3,055 PRO
    So many goodies! Pause regeneration is particularly exciting! Flatten has also come up for me a decent amount and this will be super helpful so I don't have to leave Onshape to get it.
  • glen_dewsbury
    glen_dewsbury Posts: 1,369 PRO
    edited November 2024
    Kudos OS. Some vary nice updates today, especially flatten. I like the spread sheet connectivity as well and hope it propagates into other areas as well.☺️
  • the flatten surface feature that has been long awaited, it would be better to have an option to export to tab and the result of this flattening to become a part or surface so it can be modified again.
  • Konst_Sh
    Konst_Sh Posts: 169 PRO
    Suspending on regeneration is great as well as flattening. Having the flatten feature with in-part studio surface result would be pretty useful though, especially if it would be possible to create inverse transformation of the objects associated with flattened surface to the curved one.
  • GWS50
    GWS50 Posts: 528 PRO
    Flatten surface and from a mesh too…..wow thank you that is unexpected but very welcome
  • bryan_lagrange
    bryan_lagrange Posts: 1,036 ✭✭✭✭✭
    Big plus with sketch profile inspector.
    With the launch of flatten surfaces does this mean we are getting closer to the release of sheet metal loft??? crossing fingers……..
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • EvanReese
    My thoughts exactly. It seems like this functionality could converge on something like a mix of sheet metal flat view and UV unwrapping for texture mapping. I could certainly see a "Flatten" feature that behaves like the sheet metal feature, and would open up a lot of modeling power. This could also make complex decals possible across multiple surfaces of any kind. I get that this is likely an order of magnitude more work to do though, and I'm very grateful to get the flattening we see today.
  • dirk_van_der_vaart
    dirk_van_der_vaart Posts: 561 ✭✭✭
    Flatten surfaces, one small step. Next step flatten cone's etc.
    Export to SVG
    Next step import SVG???
    In 4 week's it is christmas ???
  • brucebartlett
    brucebartlett Posts: 2,148 PRO
    The flatten looks great. I am looking forward to using it.
  • Love the new flatten feature, I would love to see edges show up in .DXF for fold lines and stuff.
  • GOLD! hell yeah flatten is sick even though I don't use it at work and pause regen is going to save me from moving the regen bar over and over and over again! THANK YOU!
    Love the Google tables coming in proper and sketch inspector will come in might handy when I import PDF's converted to DXF's
  • beautiful features. also very happy with the sketch profile inspector!
  • ben_partouch
    ben_partouch Posts: 162 PRO
    Awesome release. Flatten surfaces is major. Thank you!
  • adam_richardson
    adam_richardson Posts: 35 ✭✭
    UV texture mapping is where my mind went right away as well…
  • MichaelPascoe
    MichaelPascoe Posts: 2,943 PRO
    Wow wow wow!
    RENDERCAD
  • with you on this!! hopefully a nice big final Chrismas release for sheet metal!
  • 3D_Brooklyn
    3D_Brooklyn Posts: 7 PRO
    Flatten surfaces and pause regen are huge!
  • 王振翊
    王振翊 Posts: 7 EDU
    展平功能太棒了!
  • I also like the sketch inspector a lot. A good CAD needs handy tools like this.
  • Misael
    Misael Posts: 11 PRO
    I've been waiting for these features!! The sketch inspector it's such a time saver. And the flatten surface… well, it's like Christmas already!!
  • JosefBurjeta
    JosefBurjeta Posts: 30 PRO
    Fixing the decreasing degree of Bezier is great. Previously we could end up with straight line after several iterations as shown in my comment.
    I really like pasting table with initial, simple formatting. Looking forward for additional improvements. 🙂
    Profile inspector went a great way from the early stages, it's really cool now and will quickly help find holes and repair sketches.
  • Is there a clearance check tool in Onshape? Vote for clearance check tool to be added! 😀
  • HeRo
    HeRo Posts: 4 PRO
    Very nice update! I'd love to see a "pause" mode in render studio aswell so that one can assign materials, adjust the perspective, etc. without Onshape rendering all the time. With larger assemblies that is quite time consuming.
