How do I move a sketch attached to a part?
I'm trying to center a sketch onto a certain part, but it keeps snapping to one place.
  • martin_kopplowmartin_kopplow Member Posts: 1,317 PRO
    edited November 2024 Answer ✓
    Sketches never (intentioanlly) snap to a point. There are at least two solutions:
    1. Try the "Use" tool to transfer your desired reference into the sketch, the draw from there.
    2. Use a mate connector instead of a sketch. Attach it where you want it. You can then sketch on a mate connector's Z-plane just like you would on a sketch plane.
  • micah_staffansonmicah_staffanson Member Posts: 4 EDU
    Oki
