Every time I visit the onshape website I need to log in again. Is there a "remember me" option?
The first onshape browser tab I connect in Chrome requests login info every time. Can onshape "remember me" when I connect from the same device (laptop)?
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 664
    Are you clearing private data on closing of Chrome?  Your browser should have a cookie with your session that should remove the necessity of signing in again until the cookie expires.
    Jake Ramsley
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 405
    You will need to login again after 4 hours of inactivity. This is an important security feature. We realize that this is more important to some of our users than others. If having this feature is important to you, please open up an Improvement Request in the categories on the right side of the page.
  • dimitris_mertzisdimitris_mertzis Member Posts: 3 PRO
    Thank you for your answers @john_rousseau and @jakeramsley. However inactivity is not the reason since it happens every time I open the first onshape browser tab irrespective of time elapsed. Regarding cookies, every other website works fine so and I do not delete cookies. I do not even close chrome at all. Every time I open the first onshape chrome tab, my credentials are requested.
    Hi @dimitris_mertzis. Sorry you are running into this issue. It's not the way it's supposed to work. It's also not the way it works for everyone else. It looks like you are running Chrome on Windows 10, which is a very common configuration.
    Are you running any ad blockers or privacy plugins? Are you signing out of Onshape before you close the tab?
    If you can't find a plugin that's causing this, please open a support request from in Onshape via the "?" menu.
  • bendhowardbendhoward Member Posts: 4 PRO
    I disagree that frequent automatic logoffs are an important security feature. Does gmail log you off every morning? Please let users make this decision themselves.
  • hunter_reed887hunter_reed887 Member Posts: 3 EDU
    I think the easiest way to bypass this is to set your browser to remember your login info. I do this and it makes logging in much easier
  • andrew_ward338andrew_ward338 Member Posts: 4
    This is incredibly annoying, and I disagree with the rationale of it being a security feature. At best, it should be a org/account setting
    Also, Onshape stops 1Password from being able to enter passwords which means it's not a solution
  • MichaelPascoeMichaelPascoe Member Posts: 2,346 PRO
    edited July 2022
    For myself, no one is going to get much data from me by stealing my models. I would love to always be signed in.
    On a separate note regarding comment #5:
    Gmail != secure;  // =P
  • romeograhamromeograham Member, csevp Posts: 706 PRO
    @andrew_ward338
    1Password works well for me with Onshape. Both the browser extension and the desktop version (Windows).
    For an enterprise security standpoint - it's important to adopt best practices (per @S1mon) and leverage password managers / 2-step verification whereever possible. If the password manager is setup and working well, it's very low-friction, and best-available security (and fits well with your generally-secured life. You should be using the same strategy for your Gmail and Bank logins too!).
    I can see how it's a nuisance for those with a computer that is physically secured, but for folks that travel or work on various machines, this security layer makes Onshape usable.
  • kenn_sebesta167kenn_sebesta167 Member Posts: 93 ✭✭
    I, too, am annoyed that OnShape signs me out.
    The security argument does not pass muster, esp. because I have a free account and so all my models are public anyway. There are far more people who want to break into a random user's gmail or outlook accounts than OnShape, and those have sane policies which allow me to stay logged in. My password manager, which is far more sensitive, allows me to stay logged in. And then I use that password manager to log into OnShape. If it's safer to aggressively log me out, then it's trivial at best.
    If there are CPU reasons, then by all means, log me out. I'm not paying for OnShape, so if I can stretch their dollars that little bit more then I'm happy to periodically click Login.
    edited July 2022
    Onshape will log you out as soon as you close all of your cad.onshape.com browser tabs, which ends your session.
    After that your browser should remember your username and password and auto fill them. So you just need to click the login button. That's the way it has always worked for me.
    If you don't get the prompt from your browser, that means you probably hit the option to 'never remember for this site' the first time you logged in.
    So you will probably have to dig through your browser security settings and saved passwords and add it there.
  • peter_m091peter_m091 Member Posts: 8
    I also find the automatic log out as just an annoyance, as opposed to a real security feature. There are so many other secured apps that have no need for this. It's all about reducing friction, so please remove the 4 hour bump (or at least offer people the option to stay logged in on the same PC)
  • tony_fernandez233tony_fernandez233 Member Posts: 2
    I think I have a solution for you all, I do this for a work business app and can't see why it would not work for Onshape
    Download, a web page refresh extension for your browser of choice, open a new onshape tab, set the tab to auto refresh every 5 mins or whatever you wish, then pin the tab, so you don't get confused.
    Now you should be able to use Onshape in a separate tab without it timing out.
    I hope this helps!!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,864
    I hope this helps!!
    I imagine that would be incredibly annoying if it refreshed when you're in the middle of sketching.
    The time out is not bad anymore. You can click the blue bar at the top of the screen and it will allow you to continue working instantly. Refresh is now a last resort
  • davidg707davidg707 Member Posts: 4
    I too am annoyed by the logouts, and the questionable claim that logging people out is a security feature. My PC is locked inside my house, what extra security does logging out add for me?
    In fact, I can't think of a scenario where security is actually improved by automatic logout. Let's say someone actually takes my computer, and has logged in to Windows somehow. If they're after my OnShape data, firstly, I have my passwords saved so they can still log right back in without knowing the password. And even if I didn't have passwords saved, they could reset my OnShape password because they've got my computer and thus access to my emails.
    Any security conscious person isn't leaving their computer unlocked anyway, so it just seems like a weird decision to make, like no one at OnShape has really thought about security carefully.
    Maybe there is some very rare, convoluted scenario you could come up with, a one-in-a-billion occurrence, where automatic logout protects your data, but there's absolutely no reason to make it mandatory for everyone else.
  • PauloPaulo Member Posts: 24 ✭✭
    @davidg707 if you want to have passwords saved to compromise security then that's your choice, but corporations don't want to give their employees that freedom. It's not costing you anything so suck it up.
    @Paulo saving passwords and keeping OnShape signed in wouldn't "compromise security" on my system, and that's my point. If you build a one-size-fits-all solution for security, then you have to make it as strict as possible, which is what they've done. What I'm suggesting is that this results in bad UX for people who don't need or want that level of security. I'm sure there's a way to both make this an option for individuals, and at an organisation level.
    If this isn't a concern for you, then your input on the matter is not required.
    edited December 2024
