Trying to make open irregular container
Hi everyone,
I'm trying to build a container. This is my sketch:
I've achieved a black outline, and then I copied and edited the shape again and placed it within the original shape to achieve 1.2mm walls.
I'd like to extrude the outer shape first, then the inner shape to hollow it out but first I think I need to move the smaller (internal) shape 1.2mm away from the front plane, leaving a solid wall, and then extrude the inside to 1.2mm from the opposite side to achieve another wall there. I'm very new to this so I am not sure if I'm even on the right track.
Any advice would be appreciated. Thanks!
I think your end result is to have a box with walls and bottom of 1.2mm thickness. If so, just extrude the entire sketch up 1.2mm and then use Extrude/Thin on one of the perimeter sketch shape entities. Which way (arrow selection) to direct the extrude depends on which perimeter you choose. - Scotty
yeah: like robert said: use extrude/thin option.
or extrude the solid, and use shell afterwards. no need for offsetting wall in sketches. that works, but it's not vey flexible or easy.
Thanks! I'll look at that option now. Did I go about this correctly? I spent a lot of time adding the inner boundary, but maybe I could have kept it a solid shape with a single line, and somehow converted it to a hollow object with constant wall thickness?
Sorry, I misunderstood until I did it. It's perfect! Thank you
One more question if you don't mind. I have completed the box but I don't know how to remove the top accurately. If I try to extrude/remove into the box it takes the walls off as well.
The link you provided is view only so it's not possible to examine the feature tree to see what you have done to produce the results you have. Just glancing at the feature tree, it looks like there is an abundance of extrudes. If possible, please make your document Public so we can take a peek. - Scotty
I just updated sharing to allow onshape users to copy etc.
Not sure what your calling the top, but just select whatever face and extrude cut it through the box.
This sort of part would probably be much easier to make with a shell feature at the end.
This is what I ended up doing, but the problem was that it shortened the part by 1.2mm. Not that this is a problem in my case, but I wondered how to do it perfectly in case I wanted to keep the height the same. I could have extruded/removed a rectangle from the top but since I used extrude/thin to make the item I didn't know how to select the inner top face (without selecting the walls all the way to the top).
Ooh, this would have been perfect. I didn't know about the shell feature but just read up on it and it seems like it would have been the right way to go. Next time!
Here's a different way with less extrudes.
https://cad.onshape.com/documents/ac1c929bf8a0dd2ecdff6699/w/249e292c4166ef63d3dd4c03/e/f477868495f1214f15ecbecf
You either have to cut a section to see in or set it to tranlucent like I did. then when you select the face…hover over it and press ` to get the pop up or right click and select other.
Just a question. Is the intended to be made as sheet metal? If yes, you should be working with sheet metal tools.
no, just 3d printed.
I agree with the shell Option offered earlier.
https://cad.onshape.com/documents/5f792d6cefa1e43c6841664e/w/025564033a2335b352c851d4/e/086e3c9422b4a0cca2784b7f
