Configuration Tables are awesome, now how do I export my 300 parts?
brandon_furtwanglerbrandon_furtwangler Member Posts: 12
As far as I can tell, every time I make a change I'm going to have to manually configure the part & export all 300 variations manually?  That will take days...
Is there a better way?  I as hoping for a 'export all configurations' where I can feed configuration settings into the export template somehow, but I can't find anything like this.  Have I missed an easy way to do this?
If you're wondering why I have 300 configurations - it's because I made a keycap configurator and their are several factors the combine (shape/profile/size/homing).
https://cad.onshape.com/documents/0834293e74af4c6a396f8eab/w/f486ecb436e3b08b4a3a7007/e/eba3ef0267cc4c6c5161806e?configuration=List_NyThPuBqySRLMD=homing;List_f6j0re8WqI0TiW=Default;List_hn0GuVRdS6CNqY=Copy_of_edge;List_tfUVaJqjqApmxI=u1
  • Alex_KempenAlex_Kempen Member Posts: 255 EDU
    edited April 2021
    You could write a FeatureScript to import your configured part studio repeatedly, cycling through the different configurations using the configuration option of the instantiator module. Then you could shift select all the parts in the part studio and export them as individual parts. Not ideal, I know, but better than manually configuring and exporting a ton of variations. You might also need to limit it to a couple dozen variations at time to keep performance at a somewhat reasonable level.
  • brandon_furtwanglerbrandon_furtwangler Member Posts: 12
    thanks.  that sounds 100x better than the alternative.  will give it a shot tomorrow.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    edited April 2021
    I have done this with the api and might be the fastest way to do this. 300 parts in a studio does not sound terribly performant.
  • 3D_Brooklyn3D_Brooklyn Member Posts: 7 PRO
    I'm a complete novice when it comes to featurescript - has anyone made this so I can use it or does it have to be customized per project?
  • rajasekarrajasekar Member Posts: 3 EDU
    Hello, do we have any progress on implementing this feature? I'm also interested in it. I've set up numerous configurations and would like the ability to export all these configurations simultaneously, each under its own name, either as STL or STEP files.
    I'm not really great with FeatureScript so if anyone can share their code to export files that would be really appreciated. Thank you!
  • Caden_ArmstrongCaden_Armstrong Member Posts: 332 PRO
    @rajasekar
    My application Renaissance has a tool that can achieve this.
    You can find it in the app store here:
    https://appstore.onshape.com/apps/Utilities/NDYJQNNF4DWNBG4O6QLFTN4UIPRDQ2B7ABZSFXQ=/description
    www.smartbenchsoftware.com --- fs.place --- Renaissance
  • wyatt_wolfwyatt_wolf Member Posts: 2
    Does this work after a part has been renamed manually? It doesn't seem to for me
    @wyatt_wolf if you're having any issues, please send me an email so I can troubleshoot them.
  • zixi_zixi_ Member Posts: 3
    I wrote a quick python script with the Onshape API to export all configurations of a part in a part studio, naming each item as its named in the configuration table. I've only tested this with what I'm using it for: nametags for many people, so I'm not sure how well it handles scaling up (i.e. multiple configuration parameters, etc). https://github.com/ZimengXiong/OnshapeBulkExportConfigurations
