Create a gear teeth on an oval ring gear
I'm trying to put teeth into a oval ring gear. Similar to something like this picture. I can make the outside oval, but for some reason cannot make the teeth and pattern it around the oval. I also have a larger ring and many more teeth so making them individually would be a large task.
Here's my doc.
https://lgsstudent.onshape.com/documents/6904657e3fa4e115f1b08bef/w/09b740610468bf301139b31e/e/1be664349011cd995f86a824?renderMode=0&uiState=677ff7b78a66882a7886efbf
Any help appreciated. Thanks!
