ARM64 Support - Snapdragon X Elite
parker_bradshaw589parker_bradshaw589 Member Posts: 2 EDU
Is onshape offically supported on ARM64 as opposed to x86? I see one forum post suggesting that some sketch/selection? functionality might not work. If not then I will not take the risk buying an ARM laptop.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,866
    As long as your browser supports it, we do.
    You can always try it in the store before you buy.
  • Ste_WilsonSte_Wilson Member Posts: 471 EDU
    It runs just fine on my Raspberry Pi 5
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 405
    Every Onshape developer is running an ARM laptop. @NeilCooke is right. If you have a browser that works, Onshape will too.
  • parker_bradshaw589parker_bradshaw589 Member Posts: 2 EDU
    Great, thanks for the info!
    @parker_bradshaw589 please hold off on your purchase. Two different people reached out to me internally and pointed out that there is an open issue with Snapdragon(R) X Elite - X1E80100 and Onshape.
    I'm not sure if it's something that we are going to be able to fix or if it's an issue with the Snapdragon.
    My apologies for the incorrect information!
  • maciekmaciek OS Professional Posts: 29 PRO
    any news? I just bought the Microsoft Surface Laptop with Snapdragon X Elite 😑
    @maciek What exactly doesn't work? Does the in-document canvas (3D area) not work when you open a document? Are you running Chrome or Firefox? Are you trying to use flags or overrides to force webGL to load? Send some details and I can reach out directly to see what else might be in the mix.
    Just have a look - https://streamable.com/rzngp2
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 651 PRO
    An issue has been identified. Fingers crossed that it will be resolved in the next release.
  • EvanEvan Onshape Employees Posts: 65
    With Onshape release 195 we believe we've resolved the selection issues on the Snapdragon X Elite GPUs. We were getting garbage data back from the tiny pick buffer we use to support selection. We've applied a work-around and have seen the issue improve. Please let us know if you find the issue is not resolved.
