If I sketch a line in Onshape Drawing for example 200mm how can I change it to be 250mm ?
Marin_Marciuš
Member Posts: 7 ✭
My main question is if you can change length of line you make in Drawing mode?
In most CAD systems, You'd just put a dimension on a line and type the lenght you want it to be.
Yes, I know, but here I put a dimension on line and it only overrides it(it changes the text but not the length).
Here, where? In a sketch in a part studio dimensioning a line will set it to the correct length. Where aren't you seeing this behavior?
HaHave you tried the learning centers self paced courses?
https://learn.onshape.com/
Does not work in drawing mode at this time.
I pretty sure there is a ER for this if you can find it. Was a while back.
Sorry, I meant in Onshape, my bad. And I am not sketching in part studio, I am sketching in drawing, I want to sketch borders for my template.
If you want to make a drawing border the best way to do it, oddly, is to create it as a sketch in a part studio then export it as a dxf. You can the import it into the drawing with the dxf button, to the rightish of the toolbar.
