Struggling with text orientation
I'm trying to put extruded text on opposite sides of a simple object. Let's for, example, say the text is "FRONT" and "BACK". I can place the "FRONT" text OK, but when I place the "BACK" text on the opposite side on the object the text is backwards, and often upside down as well (but oddly not always upside down). I can't figure out how to get it so it reads in proper direction.
Here is an example. If you flip the disk around a vertical axis to see the back, you'll see the problem.
https://cad.onshape.com/documents/b3bf08d5d93943d097ce00b9/w/e1d8040a9f8644f1821537d8/e/3e1d2f6c324d484cb325c840
