why is the square not fully defined?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,930 image
    Drag a blue line to see how it behaves.
    HINT: add a midpoint constraint between the end of the construction line and the bottom line of the rectangle.
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 945 ✭✭✭✭✭
    Need to place a dimension from the edge of the part to the edge of the cutout. Alternatively if it is center then a relationship of midpoint of cutout to midpoint of part.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • MDesignMDesign Member Posts: 1,265 PRO
    a number of different ways to constrain it. as suggested by Neil and Bryan and you could just use symmetry as well. but the general idea is that the system doesn't know how far left or right you want to keep the rectangle position
