Struggling with text orientation
len_2
Member Posts: 8 ✭
I'm trying to put extruded text on opposite sides of a simple object. Let's for, example, say the text is "FRONT" and "BACK". I can place the "FRONT" text OK, but when I place the "BACK" text on the opposite side on the object the text is backwards, and often upside down as well (but oddly not always upside down). I can't figure out how to get it so it reads in proper direction.
Here is an example. If you flip the disk around a vertical axis to see the back, you'll see the problem.
https://cad.onshape.com/documents/b3bf08d5d93943d097ce00b9/w/e1d8040a9f8644f1821537d8/e/3e1d2f6c324d484cb325c840
Your example displays properly for me? Neither backward or upside down (when rotated vertically, I suppose it's upside down if spun sideways around a vertical axis).
What happens if you write the text on the 'front' plane and mirror it then remove the original? Would that work?
It's actually easier than you think.
https://cad.onshape.com/documents/646253eead84426a84770e46/w/d193549e6568450c8d906be3/e/f957f390632f4f31bee53d6e
https://cad.onshape.com/documents/8ba6a3a478b145f2ab7b9f7b/w/93e3539053f744a1b3e6c50e/e/3ead7bc09f184ffa845e8931
Verreee crafteeee... and somewhat cryptic.
The reversed text is a bit more of a fiddle in the case where there is not a parallel face on the opposite side of the part on which to conveniently sketch the desired text, no?
I knew you'd say that ! (it is, indeed, a "bit more of a fiddle")
It would be scraping the bottom of the barrel, I feel, to resort to such inelegant kludges as creating a 180 degree (reversed plane) by stacking up two 90 degree intermediate steps...
I look forward to the day when we have a "Flip Plane" command in Onshape.
I'm not aware that even SW has got around to that as yet. I'm not averse to a bit of flip flopping!
@philip_thomas
It is a bit tangential to your conversation, but I have just finished a FeatureScript that makes it easy to add text along a curved surface, adjust spacing, etc:
You can adjust the text orientation, but also the height, spacing, and the curve along which the text rides:
Enjoy, and of course I'd love feedback if you've got it!
