delays in deleting
digitalcarbon
Member Posts: 105 PRO
in General
there seems to be a delay in deleting at times....note the image...
there were some major updates i did when opened, took several update all button pushes...maybe everything needs to catch up...
delays
delays 0
When you use the link document update button it sounds like you have a few layers of linked documents. Perhaps if you share an image of your instance list that would be helpful as well.
If you submit a support ticket and share the document with support we can take a closer look.
Twitter: @bradleysauln
Hopefully at some time in the future updates of context, will be automatic, like saves, and order of operation will not be so much of an issue
