Thanks for the feedback @EvanReese @chadstoltzfus @Nick_Holzem . Some of what you're asking for is already planned.
@MK81 This is not implemented yet, but coming soon.
Oh Wow! I can't believe we can finally control configuration input visibility! I haven't tested yet, but I am crossing my fingers inputs get set to there default values when there hidden state is triggered.
Edit:
It does! 😍.
Exactly what we needed for configurations ..
I just used the configuration for the first time in a project. Worked great. Thanks for this improvement. I love the Onshape configurator; it works as all great configurators should!
best update so far this year….🙃
Greatest Update this year! Can only be beaten by the Sheet Metal Loft Feature 😁
@bryan_lagrange Maybe they meant "Supper Data"
Interstellar… mmh…
Thats very mean and very funny 🤣
This is one of your best memes 😂
Twitter: @BryanLAGdesign
I just noticed a change in Onshape that does not appear to be documented in this release. Maybe an 'easter egg'?
The 'Tag Profile' feature is now just called 'Tag' and is no longer located with the frame tools. The icon also has a subtle change. There is a new drop-down option giving functionality for both 'Frame' and 'Form'. The documentation still describes only the old functionality.
Before:
Now:
Interesting…
@sebastian_glanzner looks like someone is still salty from your GPT posts! 😆 This means we can narrow it down to someone who is a returning forum member. We will find you! 😈
What change? Looks the same to me.
I fell like we might be getting sheet metal forming features soon… (the "sketch for flat view" kinda gives the game away!)
Ooh! Forming tools must be cookin'!
Independent Onshape Consultant | Industrial Designer
I agree that it seems to suggest forming tools, which is exciting!
Whose idea was it, to name the extrusion feature like that, when newly created?
I'd still prefer a first step of mandatory manual naming any newly created feature, because it's an important piece of documentation. But this automatic name now is in my opinion - excuse my french - crap.
And renaming should be also enabled by a double click into the name field, as mostly any software supports that intuitively.
It took a whole week to find the changes to the Tag feature, you guys are slipping s/
There have been hints since V2455, since formed tools need to be handled in patterns etc.
registerSheetMetalFormedTools.fs has existed since then.
Also noticed that acorns have made a comeback…
@MBartlett21 here is the original Parasolid developer considering what to name 0-dimensional body topology ^
@ilya_baran I can see the logic but it makes things incredibly frustrating.
It's already difficult as it is having "exclude from properties" the only way to prevent varialbe parameters making property tables literally impossible to use. Now we can't exclude parameters from properties even if they don't impact properties just so we can make them visability controlled and now have to manually multiply our configured property tables. Insane amount of redundent work.
A good example would be a peice of hardware with two variants one of which has colour options. I want the colour option to only be visable when the correct vairant is selected but I don't want that varient option to have an impact on the properties.
Please consider either enabling excluded paramters to control visibilty of non-excluded ones or rework the configured properties interface. Moreover excluded porperties are not excluded from appearance configured property tables, only part configured property tables, not sure if this has been noted yet.
Just waiting for 3 bend corner relief to be added to sheet metal in Onshape so that I can move on from Fusion 360…
@Chris_D_Mentes_001 Got it. I think this will be solved once we implement configured properties wildcards.
@ilya_baran That sounds Juicy AF. 2025 is looking like a big year for onshape
Looking at the calendar, it seems like we could have a "blue moon" - a second release this month - today…
blue moon, that's one of my favorite ice cream flavors!
Configuration Logic between tables would be massive for us.
