Rotation of a part around the center of mass.
sergei_nesterov
Member Posts: 45 ✭✭
Good day!
There was a need to rotate the part around the center of mass in PartStudio. The 'Transform-Rotate' function requires a specific axis around which I want to rotate. This is logical if I need to rotate around some object, but what if I do this around the center of mass of the part? I do not have suitable axes for this action, I do not want to create additional sketches for this.
This is where the question comes from. In Onshape there is no tool to rotate around the center of mass of the part or use the construction space axes? For example, the 'Translate by XYZ' function can move an object along the axes without specifying a specific line. This means that the object has its own axes
(Also, note that, in my example, I could've simply put an implicit mate connector - that circle button next to the Axis parameter - on the front face, where it would've computed the centroid of that face.)
Or copypaste into a Feature Studio in a doc you own.
The trasnform tool in onshape is such a pain to use.
@doeke_wartena
Why? What are you trying to do? Why comment that on this thread?
Perhaps try the learning center and/or ask some questions. The transform tool could be improved, but I'm guessing that whatever issue you're complaining about has a much more simple solution. A lot of people coming from other CAD systems or rendering tools try to transform things over and over instead of building them the right way parametrically.
I wonder whay the mass and section properties dialog has no check box to create an MC at CG wile it is at it calculating.
Here or maybe next to the mass override check box. That would really make sense and it'd be at the place it is expected.
@doeke_wartena @S1mon
I can partly understand Doeke's opinion. But Simon is right, it is the wrong thread. Does this forum support forking threads in some way? I can't apparently quote to a new discussion. I'll open a new one, then:
