Unable to Add a Dimension To a Curve On a Drawing
Tyler_MurphyTyler_Murphy Member Posts: 2
I am unable to add a dimension to the curve pictured below (closest to the virtual sharp). When I have tried to dimension it, it will not allow me to select the curve.
  • martin_kopplowmartin_kopplow Member Posts: 808 PRO
    Are you sure this curve is an arc? If it is not (maybe due to projection issues) it'd be a quarter ellipsse or such and then you can't throw a radius dimension on it.
  • S1monS1mon Member Posts: 3,339 PRO
    To my eyes they are definitely not concentric arcs the way they would be in a sheet metal model. The outside "arc" also looks like it might be a spline.
