OnShape issues with Linear Pattern one of the pattern objects disappears after completing the sketch
travis_grenelltravis_grenell Member Posts: 11
1. I have a linear pattern and it's disappearing one of the elements in the pattern for some reason when I click the green check! Screenshot below. What is causing this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,973 image
    Edit Extrude 4 and add the missing sketch region.
  • travis_grenelltravis_grenell Member Posts: 11
    Ahhhh thanks, that was confusing!
  • doeke_wartenadoeke_wartena Member Posts: 5
    Note for other people having a simulair problem. In my case I thought the first shape was removed, but the sketch was set to not visible so I had to click the eye icon.
