how to create a pattern along the dashed line?, i want to create 10 equally spaced holes.
abanoub_samyabanoub_samy Member Posts: 3 EDU
so, im new here, still leaning, was able to make this model in 3D, as the title i want to make 10 equally spaced holes along the dashed line, using the patterns tool i only have two options, Linear and circular patterns
when i was young i learned on autocad but for 2D drawing only, in autocad there was an option to create a pattern along a specified line, like this whole dashed line, how to do this here
also is there a dedicated place to post questions like this for newbies?
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Hey @abanoub_samy,
    Dropdown under the linear pattern you can find the curve patter.
    The "Using Onshape"is probably the best place for general usage questions. Cheers
  • MDesignMDesign Member Posts: 1,265 PRO
    What @David_YL_Nguyen is suggesting is for feature/model mode. What @abanoub_samy is asking for is sketch mode for which there is no curve pattern. So you will need to create a single hole via sketch/extrude or hole tool. then curve pattern it with the tool david is suggesting.
