How to make a loft between a face an a line?
Im am currently working on an 1500mm RC Corsair but can't quite figure out the wingtips. Is there any way to create a loft or something like this between these lines?
Please don't judge, I just began with onshape 1 month ago and this is my first "bigger" project.
We are like Planet Fitness. no judgement zone here. haha. That is a great case for fill surface with guides potentially as 1 surface or 2 at the most if the fill doesn't like the guide coming to a point(s). I highly recommend the surfacing training in the learning.onshape.com site There's a specific example showing something similar at some point in there.
You can do this by lofting to a point and using the curves as guides.
https://cad.onshape.com/documents/fb70f74cda58c292a7247904/v/d8fb1152222498ef0e135e29/e/7c7dc35fc720daa8ec229472
Forever requiring approval :(
Alternatively you can just loft face to sketch region also with a guide.
Thanks to all of you! For me making a fill and than thickening it worked the best as I decided to make it with a thin outer wall
