Improvements to Onshape - January 31st, 2025
13
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,049 PRO
    He has a lot of videos on youtube machining aluminum, and I think steel too. I have my Taig in my apartment (it was at my dayjob where I used it a lot then). It is fairly quiet because the spindle maxes out at 8000 RPM, using a belt drive servo motor. I only use it once every 6 months or so. The Sharif DMC uses a 20,000 RPM range router motor, as do almost all the hobby cnc's. Those will be much louder. IDK if they still have power if the speed is turned way down.
  • EvanReeseEvanReese Member, Mentor Posts: 2,789 PRO
    Great update! Form tools are a big win
  • onsf59onsf59 Member Posts: 1 PRO
    edited February 2025
    Hi,
    Can the form tool create a form into a bend like the part in the picture below?
  • FarraFarra Member Posts: 11 PRO
    Is there a way to get this in an existing part studio ? it only shows in new studios
  • Nick_HolzemNick_Holzem Member Posts: 194 PRO
    @martin_farrow submit a support ticket to have the new features pushed.
  • don_williams909don_williams909 Member Posts: 147 PRO
    Can someone please show me how to use the form tool on a curved part, or to create a curved part?
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 224 image
    Give me a sample 3 axis part and I'll cut it on my TM2P and make a video from start to finish.
    Support & QA
    Can you share an image or a link to what you're trying to do? Right now it only works on planar things. IRL, would you:
    • Have a sheet cut (lasered, plasma'd)
    • Roll that
    • Then manually use a die on a brake?
      • I've used a turret punch press machine before and non-planar things aren't really going to happen on that. Forms would just get deformed if rolled after this
    Support & QA
  • lanalana Onshape Employees Posts: 753 image
    Currently only forms fully fitting inside flat wall are supported.
  • S1monS1mon Member Posts: 3,919 PRO
    I'm very happy that we finally have forming tools, but I do hope that this limitation is addressed soon. Corner gussets would be nice, but even being able to create a bridge lance at the edge of a sheet is pretty common.
    Lance and Form Tooling Solutions | UniPunch
  • aeromorrisonaeromorrison Member Posts: 77 PRO
    Parts like the one shown below are extremely common in the aviation world. I work with parts with features such as these every day. It starts from a flat sheet and then all of the tabs are formed over a forming tool/block. This part is difficult to model in Onshape currently. It has formed flanges along a curved edge and Onshape supports neither of these conditions.
    The dream solution for a part like this is to allow it to be formed in a user-defined forming tool and then have the inverse of the new Flatten surfaces analysis tool (maybe a formed surface analysis?) provide some basic insights on the relative strain levels after forming.
    Great, thanks. I think feature-wise this would be more covered with a flange along a curved edge for a few reasons:
    • I'm sure the curvature/length of the edges of those ribs isn't really uniform/constant. Making a form on an edge for this would require a lot of setup for 1-2 uses.
    • It would be less work to do two partial flanges on a curved edge and either pattern the cuts or have a custom feature that makes x cuts on a face (given bounds of a face, number of cuts, change spacing based on curvature, etc)
    Support & QA
    @Jason_S Certainly from a modeling perspective being able to add a flange along a variable curvature edge would be a huge step forward as long as the resulting non-developable features can still be flattened. Being able to flatten it is the key concern with a flange feature like this.
    @aeromorrison in release 1.190 the Flatten diagnostic and exporter tool was released. It will allow you to flatten a form likes this. FEA could be conducted from here.
    @Nick_Holzem Yes. I referenced that a couple of comments ago when I mentioned that an inverse capability would be part of a 'dream solution'. This flatten analysis tool is awesome, but the capability isn't integrated into flat patterns like the other sheet metal tools. It's also not possible yet to bend the flanges on curved edges as a sheet metal part.
    Try throwing it in the trash and then retrieving it. That process forces the document to update.
  • dave_lapthornedave_lapthorne Member, Onshape Employees, csevp Posts: 42 image
    Post/Machine customization is something that is planned for the future, yes
    Onshape Senior QA Engineer
  • fnxffnxf Member, User Group Leader Posts: 145 PRO
    Some great stuff here, but my favorite is definitely SHEET METAL FORM. Yay! Thank you so much!
  • Shane_DillerShane_Diller Member Posts: 2 PRO
    Love the new additions but I'm struggling on the Sheet Metal Forming tools related to Louvers. It seems that they have a default orientation and rotating or changing them requires a mate connector as the reference instead of sketch vertices. Is there something I am missing? Having to set a mate connector to rotate it seems a bit silly when there could be something directly in the feature to select a sketch line for orientation.
  • michael3424michael3424 Member Posts: 753 ✭✭✭✭
    Thanks - I hope that this will be covered in the CAM Studio Webinair next week. is there a list of the machines supported with posts anywhere?
    Some great drawing updates here. Still some more to come, but geometric constraints is a massive step forward, as are the custom shortcuts for drawing tools, and stacking callouts.
    Fixed an issue that can cause dimensions to fail when applying break on a specific drawing view
    Nice :) this was one I have run into.
    Nice to see CAM Studio coming along well.
  • jan_kusmierczykjan_kusmierczyk Member Posts: 2 EDU
    I'm not sure if this was proposed a lot before, but I think that being able to extrude a point on a sketch plane with just the extrude button would come in really handy. I tried my own shot at making some mininfigures, despite the fact that theres better software out there for this, but I found that maing a tanget to a 3d fit spline (with only 3 poinst) took quite some time and created a few extra features and sketches. With this addition, I feel like I could get away with only creating a sketch plane with the spline as a normal, maybe making a point in the sketch, and simply extruding it.
    When sketch vertices are selected orientation of the sketch is being used. So you can define the sketch using mate connector for plane and then orient that mate connector. Alternative would be to place one instance of Louver and then pattern it.
  • christian_pettychristian_petty Member Posts: 82 PRO
    Thank you! By the way, the graphics in these posts have not worked on Firefox for some time for me. I have to use Chrome to view them.
    Christian Petty - Mech. Design Engineer, Radian R&D
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,967 image
    @christian_petty it's working for me on Firefox. There has also been a problem with Safari in the past. I just tweaked the post to see if anything changes - can you try again please?
  • pmdpmd Member, Developers Posts: 64 PRO
    @NeilCooke graphics in What's new posts still not working in Firefox with default Enhanced Tracking Protection on but if you disable it (click on shield icon next to URL) the images and videos work again.
    Actually it was related to tracking protection. They work on Standard but I apparently had it on Strict.
  • null_null64667null_null64667 Member Posts: 2
    Hi there, great job - the CAM-Studio!
    I'm working i the education-sector, a lot of my engineering-students like the easy-way-modeling of Onshape. But my only solution to explain CAM-strategies is actually Kir:Moto. What a pitty, with such an opportunity of CA_Studio in the basket!
    Is it forseen, that the option will be a part of the education-versions?
