Sketch: how to find, select and remove identical entities drawn on top of each other?
Gerard
Member Posts: 21 PRO
I have a sketch with duplicate entities drawn on top of each other. How to identify these so I can remove these?
https://cad.onshape.com/help/Content/select-other.htm
I am familiar with the select other options, but I deal with sketched that have 100+ line entities, some are drawn 4 times on top. I like to quickly find all automatically, not having to select each one at the time. Does Onshape have an option for this. I believe I use to have this option in SolidWorks under sketch tools.
I can't think of a specific tool for this but sometimes the left-to-right rectangle selection can help. It will grab only items fully inside the selection box, not ones that overlap the box.
Matts suggestion is best so long as the end points don't line up with other endpoints. π€¬π€£
Thanks, but that does not offer a solution. Unfortunately, I am talking about identical entities, with identical endpoints. And many of these.
@Gerard I assume these are imported sketches? You could process them in another tool. ARES Kudo (available as a paid add-in for Onshape) apparently has a command called DiscardDuplicates:
https://kudo.graebert.com/help/additional/hlpid_edit_discardduplicates.htm
(I've never used this command, and as a non-AutoCAD users, ARES makes me very cranky to try to use, but I could see depending on your needs, it might be well worth the cost/effort.)
Thanks all for your feedback. It has answered my question, Onshape does not offer a solution. It would be nice to see this feature added.
As a side note, if the entities are actually duplicates, Onshape doesn't really care as it should still be able to use the regions (for solid operations) or edges for surface/thin features.
I guess I'm asking what workflow you need to remove the duplicates forβ¦
Thanks Eric, I know, but the sketch is used as driving, configured sketch, so needs to be in perfect condition. I have manually cleaned it all up, I just found the issue to be a possible improvement in Onshape. A nice to have . . . π
Nothing automatic.
The rare times I've run into this, I select the line and press delete, then repeat, until there is no line on the screen. Then I press the undo button once to get the last line back. Repeat with the other duplicate lines.
Hence my suggestion for improvement . . . π
Make an Improvement Request. I'll vote for it. π
