How to re-order columns in configuration tables?
nicholas_withamnicholas_witham Member Posts: 17 ✭✭
Hi, ultimately I would like to be able to rename columns in configuration tables, but I know that is not possible right now.
Is it possible to re-order the way columns are displayed in a configuration table? You can see below that the upper tables don't match the lower tables. No matter what order I select them in, the columns always end up in this order. Does it have something to do with the order those dimensions were placed?
