make a surface from between 2 closed 3d curves
I've a curved surface of a part I want to put letters on it. I've found that using prjected corved gives me the best result. it works for all letters exept "o" since "o" is made off 2 closed curved while other letters makes 1 closed 3d curve. from the curve I use fill to make a surface.
how can I make a surface from the letter o?
example:
https://cad.onshape.com/documents/8ce39354117f0d31df72cf62/v/36ba547dd4f887b47bf8a9ee/e/8abfcb8d73940457c32f8d37
