API Support for C# Application
Good morning,
I have been going through the examples for the API and looking for a little help / guidance from the community on how to accomplish my sample task.
In essence I am trying to create a new drawing, insert 2 sample DWG blocks inside it at specific coordinates, and then export the drawing to an Azure BLOB. All of this needs to be done programmatically using API calls with JSON from my application.
  • I can create the drawing (Example.dwg).
  • I can add an OnShape Drawing (Tab) to the file (Called TestDrawing). This TestDrawing is small (looks like 8.5 x 11), so any help on how to modify the JSON call to make a larger drawing, or one based on a DWG title block, would be very helpful!
  • I can't yet insert test blocks onto the TestDrawing. The files are located in a folder BlockLibrary and called Test1.dwg and Test2.dwg. I can get the Document ID and Workspace ID of the Test1 and Test2 files, just can't get the JSON insertion to work.
  • Haven't gotten this far, but next step would be to export TestDrawing as a DWG to an Azure Blob Storage. I've got code ready to try to turn the file into a MemoryStream and send to a Blob, just haven't tested it out yet.
    • var request = new RestRequest($"drawings/{drawingId}/export", Method.Get);
    • var response = await client.ExecuteAsync(request);
    • return new MemoryStream(response.RawBytes);
Thanks for any help you can provide on the API / JSON calls!
Best regards,
Richard
  • susan_pedicinisusan_pedicini Member, Onshape Employees Posts: 5
    Hi Richard,
    We currently do not support inserting DWG blocks into Drawings via the API. You might try creating a template with the DWG blocks and creating a drawing from that template, using these steps:
    https://onshape-public.github.io/docs/api-adv/drawings/#create-a-drawing-from-a-template
    Susan Pedicini
    Onshape Technical Writer
  • richard_defreitasrichard_defreitas Member Posts: 4
    Hi Susan,
    Thank you for the reply- maybe I can explain what I'm trying to do and you can let me know if it seems like a supported use case of the API and OnShape- I have an application which I would like to have programmatically create a drawing; take a bookshelf for example.
    • If the user selects 32"H x 60"W, insert the symbol or draw the frame for the bookshelf. If a different height is selected, draw/insert a different frame.
    • Add accessories to the bookshelf such as number of shelves, etc. This would insert/draw different symbols based on what's selected.
    In essence, programmatically creating the drawing, and the initial thought was to have the components in DXF/DWG format for insertion at coordinates as necessary but sounds like that's not an option unfortunately. Are there any other ways you might suggest approaching this problem with OnShape API?
    Thank you,
    Richard
    Hi Richard,
    You can use configurations to insert specific Part or Assembly options. You can read about how configurations work here:
    Susan
