What is the official 3D sketch feature of Onshape?
md_ar_rahman_dipmd_ar_rahman_dip Member Posts: 18 EDU
Hello,
I actually come from SolidWorks background. I cant find the official 3D sketch feature of Onshape.
It would be helpful if anyone could help.
Thank you.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 846 PRO
    edited March 7
    There are several tools in Onshape to make 3D curves. In particular, 3D fit spline and Bridging curve.
    And while not technically "official" you should definitely check out Routing Curve and Control Point Curve:
    https://cad.onshape.com/documents/2c2c376d9979115f9f969a08/w/0507e500181f7d6b778e86ec/e/929d02bbbb5f71c6176ac653
  • Jake_DelanoJake_Delano Member, Onshape Employees Posts: 43 image
    We also have the routing curve and control point curve tools available to help with some 3D sketch workflows as well, see forum post here https://forum.onshape.com/discussion/24874/routing-curve-control-point-curve-introduction-of-two-new-features-for-3d-curve-creation
