Dimension an Arc length in Drawing
davis_pearsondavis_pearson Member Posts: 2
Is it possible to dimension an arc length in a drawing? I can get the radius/diameter dimension, and the angle dimension just fine, but can't seem to figure out how to get the length. The number I'm looking for would be the same as the measure tool and selecting the arc. I could just measure it and add the dimension manually, but I'd love for it to be calculated in case I need to update the arc later
  • JaimeeowJaimeeow Member Posts: 10 ✭✭
    three years later and it still doesnt seem to exist. thats pretty frustrating that it works in sketches and part studios, yet its not able to work in a sheet/drawing model... what the heck onshape????
  • John_GoetzeJohn_Goetze Member Posts: 3
    Still not sure how it is 2025 and a seemingly basic tool for accurately dimensioning drawings has not been implemented. Hoping this gets added very soon.
  • Ste_WilsonSte_Wilson Member Posts: 532 EDU
    Feels like some smart person could do a feature script to allow it to be dimensioned in a sketch, then the sketch could be shown in the drawing,
    The improvement request is here:
    Go vote.
  • robert_melascagliarobert_melascaglia Member Posts: 45 EDU
    Well, 5/13/2025, and I need to show "a dynamic" arc length on a drawing.
    as Stan Lee would say, "nuff said".
  • c_büscherc_büscher Member Posts: 12
    @NeilCooke
    Dear Neil,
    maybe you can enlighten us with this question.
    In sketches it is posible to dimension the length of an arc.
    But in drawings it is not.
    How can we solve this issue?
    Thanks for your response.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 564 image
    @c_büscher The development work for arc length dimensions is in progress for drawings. It won't be possible as you want until we deliver on that. Currently most users call this out manually with a note.
  • hugh_rousehugh_rouse Member Posts: 8 PRO
    edited November 27
    I'm throwing a comment in here - and a request for Arc Length dim for drawings please.
    I can appreciate manually creating a call out with a note for the time being - with the disclaimer that its not robust and can cause issues downstream in manufacturing if design changes are made an it is not manually updated.
