Adding hyperlinks in drawings
bryan_lagrange
Member, User Group Leader Posts: 945 ✭✭✭✭✭
I
would like to see the ability to add hyperlinks inside
drawings.
Here
is the scenario.
I
made an Onshape document that contains tabs of documents that pertain
to the manufacturing process (weld procedures, quality documents,
etc.). These are our company specific documents that need to travel
with drawings through the mfg process. Not every job has the same
documentation so I would want to only add the hyperlink to a document
as it pertains to the job.
Instead
of having to add these documents to every Onshape document that I
create I would like to place a hyperlink in the drawing that when
clicked on, it automatically directs you to the Onshape company
document that contains the document (weld procedure, quality,
etc.)you need.
This
way I upload the company specific documents one time to a central
location Onshape document and only have to add the hyperlink to all
future drawings to direct you to this page as needed.
I took the liberty to create an improvement request here. Click and vote!!
This is a little different but related to links, I just recently raised an IR for an Onshape shorten link service like bit.ly, this could be also useful for adding links to drawings
https://forum.onshape.com/discussion/8503/cad-on-generate-a-shorten-link-to-a-tab-by-rmb-on-the-tab-to-activate#latest
I'd like to have this too. I'm using the drawing as a bit of menu for all the bits of a project. Putting deep links allows people to click and view.
